Engine Failures Thanks to Wiseco >
Old 01-20-2003 | 02:06 PM
bobby daniels
yep not many winston cup teams still use wisco !! I HATE THEM ,VERY POOR METAL,
TAYLOR OR HOLLEY OR LUNITI,WHO EVER OWNS TAYLOR THIS WEEK MAKES GOOD PISTONS FOR SURE AND J&E DOES THE BEST NEXT TO MAHLE ,WHICH ARE VERY VERY EXPENSVE !
ALSO BILL MILLER MAKE A KILLER PISTON
DON'T KNOW ANYTHING ABOUT INDUSTRIAL WEED-EATERS DO THEY HAVE PISTONS REALLY OR ,WELL I THOUGHT IT WAS A BUNCH OF MAD BUMBLE BEE'S MAKING THAT GOD FORSAKEN NOISE !!!
Old 01-20-2003 | 04:45 PM
mrv8outboard's Avatar
coolrunning racing
Default mark in
omc gives a bore spec. wisco does not. if it is a new sleeve bored to std what ever that is,and that's it no more. some shops go over slighty if you are going to use wisco's but i don't and have installed many with out problems. proper setup and breakin has always worked. fyi
mrv8outboard is offline
Old 01-20-2003 | 04:48 PM
I learned all about Wiseco with my CR125 back in High School...
Back4More is offline
Old 01-20-2003 | 05:32 PM
hp500efi's Avatar
Member #9
Like the others, I WILL not nor have I used them in any of my 2 stroke MX Bikes or ATV's. Others warned me years ago to stay away from them.
Member of the Liquid Jungle
hp500efi is offline
Old 01-20-2003 | 07:03 PM
Ok. So everyone says stay away from 2 stroke Wisecos.
What about 4 strokes any problems???
DAVE
Dave F is offline
Old 01-20-2003 | 07:20 PM
Goodfella's Avatar
GOT MERC?
Cool
To answer your questions, I think the first failure was due to a piston ring land failure. We were testing in Freeport in the Bahamas and got a shower of oil and aluminum out one of the tailpipes. When the ring land lets go at 7500 RPM it just starts sending shrapnel thought the whole engine and the piston just becomes a ball.Second failure was in the piston pin area at The Worlds in the second race. Same result tons of aluminum.
Goodfella is offline
Old 01-20-2003 | 07:27 PM
mcollinstn's Avatar
I don't trust ROUND pistons. All the good ones are cam turned and aren't really ROUND when cold...
I've used Wiseco's in Merc outboards. Overbored additional .0015 and opened ring gap additional .005
Never had a failure. Also never used any over 8000rpm. Only used factory Merc pistons in the 8500 - 9000 rpm range...
mcollinstn is offline
Buddy OO
Drives and Lower Units
16
08-10-2007 04:08 PM
Strip Poker 388
06-01-2007 08:12 AM
JasonSmith
15
05-06-2007 09:29 PM
Panther
03-29-2007 02:02 PM
timucin
07-27-2003 09:49 PM
