Engine Failures Thanks to Wiseco >
Old 01-20-2003 | 06:27 AM
Goodfella's Avatar
GOT MERC?
Unhappy Engine Failures Thanks to Wiseco
Had 2 Super Cat Engine failures last year in J.E.M. Motorsports40 Motion. Both failures were due to Wiseco piston failure. Has anyone come across this same situation. We were sponsored by them and were given free pistons. They were the most expensive free pistons we have ever got.
NO THANKS WISECO!
Goodfella is offline
Old 01-20-2003 | 06:30 AM
Turbojack's Avatar
How did the pistons fail?
Turbojack is offline
Old 01-20-2003 | 06:37 AM
I would be curious what failed as well. I use Wiseco as well, Exclusively.
I use them in all my Drag Race motors with a ton of Nitrous (600+ HP worth) and also use them in my boat.
The only problems I have had with them was induced by me. ( Lean Nitrous Tune Up)
I have always found very accurate as far as roundness and sizing and finish.
302SR1 is offline
Old 01-20-2003 | 06:57 AM
Audiofn's Avatar
Charter Member #232
You mean SIEZE CO!!! In the outboards they are notorious to siezing up in the top of the stroke and having the wrist pin rip out of the bottom or the piston and well you know the rest of what happens
Jon
Put your best foot forward!
Audiofn is offline
Old 01-20-2003 | 07:17 AM
Mark in So. MD's Avatar
DITTO what Audio said.
Had them in a stock Merc 200 and also put them in my 91 2.4L Bridgeport, SIEZEco is definietly the best way to describe them.
Mark in So. MD is offline
Old 01-20-2003 | 07:24 AM
26scarab's Avatar
Well I don't know about 4 stroke situations but in 2 stroke snowmobile applications it is well known NOT to use them. They seem to cold sieze quite often , even when the motor has been properly warmed up.
26scarab is offline
Old 01-20-2003 | 08:21 AM
Wally's Avatar
Were doomed!
I agree with what the last 3 just said about "Sieze-co" Ive had numerous problems on the 2-stroke side......the last time being in a snowmobile. I was told all about the "proper" warmup and stuff yet even when its fully warmed up and babied it still went and riped the wristpin out!
Never tried to use them in a car/boat engine so i wont comment on that
-Wally
Wally is offline
Old 01-20-2003 | 08:42 AM
Ratchet's Avatar
I know a few people that use them, never used them myself though. Currently, I am running, Lunati rods, & Lunati / Taylor Pistons, and haven't had an issue in 5 seasons.
Just outta curiosity, what's everyone else using for piston & rods ?
Ratchet is offline
Old 01-20-2003 | 11:50 AM
mrv8outboard's Avatar
coolrunning racing
i use them in my two strokes and they work very well. i also use them in my repairs. i do not over bore the cylinder to compensate like alot of shops do. in two stokes i have found most failures are caused by cold siezing in the cylinders. this is usually not the pistons fault. fyi
mrv8outboard is offline
Old 01-20-2003 | 11:56 AM
Two of the biggest guys in two strokes:
Sam Baker said he wouldnt recomend them.
Jay Smith said he will use them but has to do a lot of extra work, "overbore" the cylinder and other things.
mrv8outboard, why would you not "overbore"?
