Fasted Conventional V Bottom
#41
Originally posted by Fever Mike
1hyper1, ya scared of steps? A Velocity is NOT a conventional V bottom boat. Velocity has the biggest and flatest full lenght pad bottom going! I will remind you again the Velocity VR-1 is a much better riding and built boat than the old 26' Velocity 280. However it will be hard to find other pleasure boats the same size that are low in weight like a Velocity. What other 28 foot boat with full pleasure boat cockpit and cabin weights in at 3500 lbs!!!!
Velocity hulls are as thin as a potato chip. Be careful!
Again, weight for weight and engine for engine I do not see Velocity winning in F1 or F2.
The 26' Corsa's which are straight V no pad boats won all the time against the Velocity 26' 280 in APBA F1 1997-1999. The 26 Corsa Team Oatey held the F1 kilo and beat the 26 (280) Velocity Not the Intent for the kilo record that year.
Don't take your potato chip Velocity out in the rough or smooth water against a Corsa!
Mike
Mike
Weight has little to do with strength, Skater makes the strongest yet lightest boats out there.
#47
actually boy's you said coventional v bottom. velocity is not a conventional v bottom. it has a pad and a notched transom. the fastest conventional v botom to my knowledge is a stuphen
Treadwell
Treadwell
#49
The Velocity VR-1 is a screaming fast boat for what it is, and yes it is faster than the Velocity 28. However Mike is right they are allot lighter than all other boats in their size and power. To get the weight down I do think they sacrifice hull strength?? Just what I have seen and heard.
