Painting steel trailer, what do I use to protect it?
Take a good hard look at the trailer. Depending on the construction, you may only be seeing the surface. The trailer may be rusting from the inside out. Once this process starts, there is very little that can be done to stop it. It may become cost effective to purchase an aluminum trailer.
I gave my old steel trailer away after several attempts to control the rust - the rust finally won the fight!!!!!!
Member #154
I'm with Jon and RLW. My once beautiful steel box trailer is starting to rust on the outside, but I'm more concerned with what is going on inside. I've thought about re-painting the exterior but I figured why bother, it's just ten times worse inside. I'll get a few more years out of it then get a new galvanized or aluminum trailer I wish I'd thought of this when I bought the boat, what a waste of money...ugh
RLW, no it is not boxed in, but not I beam either. It looks like a box (rectangle) cut in half. The cross members are I beam. Don't know if that is a good discription but that is the best I can do. I am not going to spend a lot of money either. I am going to do it myself. Your right, it is not worth it.
Sandblasting is probably the best way to prep it.
There is a product called POR15, which, I have been told is absolutely the best way to refinish previously rusted steel. It is a two-part process, with an etching primer first, then a finish coat.
I had a friend use it on his truck frame, and swears by it. It looks bulletproof to me.
'may want to check it out.
all this is great advice but your underlying problem will ALWAYS exist
you have a steel trailer and you dunk it in salt water
no matter WHAT you do to protect the outside
the thing can and most probably will rust from the inside out
Just a matter of time.
if you can not help but dunk your boat in salt at the ramp, then consider an aluminum I beam trailer next or later in life or in future boats for no "inside" that salt can get to and aluminum wont rust, just pit and will last a hell of a lot longer than the steel ones do.
so I agree with the statements above about self etching primers and or epoxy stuff, definately will help the outside be protected but it is the area's you cant see that are going to be doomed.
J
J
The real answer is a crane. Crane your boat in and leave it out of the salt water.
If not practical, High Quality paints and primers and paints will help, but second key is making sure ALL of the rust is gone and sealing it.
have you considered sand blasting, check for corrosion , repair, then have it galvanized? made this for a friend of mine (on this i only made the frame, had it galvd. he assembled it from there)they really don't look that bad if you trick em' out a little
On the tubular trailer, if you drill and tap a air fitting and pressure gauge on the tube section, you can "pressurize" the trailer to keep the water out. If the pressure drops, you have a leak and can find it with soapy water. Other than that, I agree with Reindl Powerboats, I travel lift the boat off the trailer when it is going into salt water.
Robert
Robert
