-   -   525 Sc......good, Bad, Or Ugly (https://www.offshoreonly.com/forums/general-boating-discussion/43973-525-sc-good-bad-ugly.html)
MY OBSESSION 02-23-2003 12:03 PM
I RECENTLY PURCHASED A 1994 25' OBSESSION CAT EQUIPPED WITH A MERC 525SC. I AM NEW TO SUPERCHARGED ENGINES, THERE IS ONLY 28 HRS ON THE BOAT. IF THERE IS ANY BAD FEEDBACK ON THE ENGINE I WOULD LIKE TO KNOW. IS THERE ANY MORE MAINTENANCE ON A SUPERCHARGED ENGINE??
THANKS
ScalpTaker36 02-23-2003 12:25 PM
I had twin 525's in my 38ZX
Best engines I ever owned. 0 problems
CHANGE THE OIL!!!!!
Bote Loco 02-23-2003 12:54 PM
I also have 525sc's, they have 340 hrs. I am in the process of "freshing them up" this winter. I think they are well thought of, and all comments I have seen posted on 525 sc have been positive.
Dave
thisistank 02-23-2003 12:58 PM
I received a used super chilled 525SC from a friend of mine that had two of them in his 38 Scarab (he blew a rod threw one of them) I think there were like 400 hrs on them. So I took the other one had it gone completely through and worked. It now is putting out about 650HP. I threw it into the Baja and have 35 hrs on it so far. It has worked like a charm! Total turn key. And you should here that little wiend scream when it raps up the RPM's!!:eek: It's LOUD!! Great motor!! I've heard nothing but possitive things about them and have had good experiences with them. They ran good in my buddies scarab too. The only reason it threw the a rod is because one of the valve springs broke at about 75 MPH and things went down hill from there. They think whoever opened the motor up didn't properly adjust the springs, causing it to loosen and break form what I'm told:eek: :eek: :rolleyes:
Tank
GO4BROKE 02-23-2003 01:21 PM
My experience has been good. I'm in the middle of a deal now to make my 454 mags into 525's with stock Merc parts.
RLW 02-23-2003 01:46 PM
What blower and carb is used on the 525SC?
Rippem 02-23-2003 01:59 PM
They are for the most part bulletproof...Merc techs will tell you that as well. One of the best "blue" packages ever. They are in a reasonable state of tune, and throttle response is excellent...especially in front of 1.5 gearing. You can speed the blowers up a little and add innercoolers and make about 570 hp tops, you are limited by the displacement of the blowers
GO4BROKE 02-23-2003 04:29 PM
RLW, Wieand 177 blowers, Holley Dominator 1050
