Self Etching Primer, I Need Help Finding Some In Spray Cans! >
Old 03-24-2003 | 03:22 PM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
Default Catalyst??
I was under the impression that self-etching primers use a catalyst in much the same way as epoxy primers like Dupont DP90. Can someone verify this? I have never seen a true self-etching or epoxy primer available in a spray can - it would go bad in short order because the catalyst does not need the presence of oxygen to "set up" - it will simply "set up" in the can.
Someone correct me if I am wrong...
Budman is offline
Old 03-24-2003 | 03:25 PM
Roger 1's Avatar
Gear cases with a spray can? Someone needs to upgrade to at least a good detail gun.
Roger 1 is offline
Old 03-24-2003 | 04:21 PM
Official OSO boat whore
All the etching primers that I've used are catalized. And I do agree about the detail gun. Harbor Freight and Northern Hydraulics both have foreign ones that are really cheap.
Cord is offline
Old 03-24-2003 | 05:21 PM
mrv8outboard's Avatar
coolrunning racing
napa has it , a self etching primer , bare metal only. use it all the time.
mrv8outboard is offline
Old 03-24-2003 | 08:44 PM
SABER28's Avatar
Default Re: Catalyst??
correct budman , all the "self-etch" spray bombs are worthless. you can wipe it off with laq. thinner. cant be catalized.
BTW i believe dupont makes a self etch called dp-90 or dp-40 that is black and not that aweful green, so scratches are less noticable.
SABER28 is offline
Old 03-25-2003 | 06:32 AM
Zoomnfun's Avatar
PPG is dp-40, green...dp-90, black, not a Dupont product. It's a 2 part epoxy, not a true acid etcher. Very good adhesion qualities and works just as well. There are 2 diff cats dp401, slow...dp402, fast.
Zoomnfun is offline
Old 03-25-2003 | 08:23 AM
Roger 1's Avatar
I agree with the Zoom man. I use the same stuff on almost everthing I paint. Adhesion is excellent, even on aluminum. Just follow the directions. They don`t print them on the can anymore so you will have to get a product sheet from the dealer. Roger1
Roger 1 is offline
Old 03-26-2003 | 07:35 AM
Budman's Avatar
Zoomn, Saber28, Roger,
You guys nailed it. In fact, I used DP90 on my Bravo after I stripped it down to bare aluminum. I then topcoated it with black Imron. The result: A super-deep, gloss black finish that is impervious to solvents and very scratch & nick resistant. In fact, this finish survived a 45 MPH hit against a submerged stump with nary a scratch! Wish I could say the same for the rest of the boat!
Budman is offline
Old 03-26-2003 | 08:30 AM
Budman's Avatar
What do they use?
Budman is offline
dmaxx3500
04-30-2009 05:00 PM
kmiller
3
04-03-2005 09:05 AM
26sonic
10-20-2002 07:01 PM
