Oil Filters Froze Up......help! >
Old 04-14-2003 | 11:28 AM
WHITE-DIAMONDS's Avatar
Oh yeah, I have also tried every curse word known to man.....still no go!!!
WHITE-DIAMONDS is offline
Old 04-14-2003 | 11:34 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Can you get the filter mounting bracket off the engine/boat? Maybe sticking it in a bench vise will give you some more leverage and options.
Sydwayz is offline
Old 04-14-2003 | 12:10 PM
Fever500
Get a big a$$ screwdriver .... place the blade against the base of the filter like you are gonna chisel it ... then get a BFH and whack it in the loosey direction ... being careful NOT to hit the engine side of the mating surface with the blade.... BABY STEPS .... That's about all you can do once you've torn the rest of the filter off with all the above methods...
Last resort.. .. HACKSAW!! Doohhhh!!!
Old 04-14-2003 | 12:16 PM
Dock Holiday's Avatar
Charter Member #34
Kevin, Remind me to NEVER let you work on my boat!!!!!!!!!!!!!!
I know how you feel, I had one stuck the last time I changed my oil, and I am they guy that put it on!!!!
It can be a real bi**h. Broke one wrence trying to get it off.
Good luck
Dock Holiday is offline
Old 04-14-2003 | 12:18 PM
formula31's Avatar
Ive also had some luck using Freeze spray you can find at electronics places. Spray it all around where the gasket is. Sometimes this will freeze the rubber gasket just enough where it will skrink and break loose from the mount.
formula31 is offline
Old 04-14-2003 | 01:41 PM
doright's Avatar
Next step...short block.
/quietly empathizes....
Doc
doright is offline
Old 04-14-2003 | 02:36 PM
bobby daniels
When you put them back use a thin coat of thick grease instead of oil it won't happen again ,,,,if that oil is absorbed into the rubber gasket or the yo-yo doesn't use any or enough then wham-o you have lock down ,use grease
Another little trick I like is take a permanent maker and write on filter hrs.and date
Old 04-14-2003 | 02:40 PM
I think the last idiot that put them on not only did not use grease or even oil............I THINK HE USED SOME LIQUID NAILS!!
The bastard has turned a 5 minute job into a 5 day job.....can you tell I am pissed about the whole deal???
Thanks to everyone for all of the good advise....keep it coming....I am going to try every option until that F**KER comes off!!
W.D.
Old 04-14-2003 | 02:48 PM
BLee's Avatar
Charter Mod
Ahhhh hell, just go get a couple of 750's for that bad boy! LOL good luck Spence!
BLee is offline
Old 04-14-2003 | 03:05 PM
Talking
Brandon, you buy em' I'll be happy to run em'!!!!!!
