Problems with Imco
JASSMAN is the failure of your drive mainly the upper gears wearing. Or from a failure of a shaft breaking like the yoke mentioned by someone else. I have mainly read or heard of gear wear problems. Sorry for your trouble.
Imco, whom I thought was a better drive than the XR and I spent more money for them, I was reassured that the parts and durability of the drives would not be a problem.
My 42 Sonic with 500 efi's and bravo's have 186 hours to date on them, not 1 problem, and yes they are maintained, drive oil as well as engine oil changed every 10 hours, call me anal but thats how come my stuff lasts, This Imco B.S. has got me pissed, I got them to say that there was excessive wear on the drive thats ready to go and could go any minute, and the other drive gears are munched, it is very rare to have both faulty, unless the internal parts mentioned were not made to stds, Im not done with them.
I could be wrong but on the BMAX they use the same gears Imco uses who get them from Merc., and Teague buys his lower from Imco. It's a damn monopoly. I say go #6's or even better ARNESON.
I have a 32' A/T (no step) and it weighs about 8000lbs and I have Bravo One XR drives hanging off of Stellings extension boxes with about 680hp going through each drive. With only 50 hours on the drives since new, Mr. Gadgets and I removed the drives last weekend and we opened them up for inspection. We found that the pinion gears have excessive wear---they are the infamous "soft batch" run of gears by Merc. It was obviously a bad run of pinion gears and Merc still installed them in their drives---you'd think with all the money they make they would have a recall on the drives with the bad gears----but NO Merc can't do that----and how 'bout the spanner nut seal? Those went bad too---how about standing behind that too MERC? Anyway, I have to reach into my pocket and pay for MERC's mistakes and buy new pinion gears and HOPE they are heat treated correctly. I know that the HP I am running is over the limit recommended by Merc, but if the pinion gears are wearing and the spanner nut seals are leaking even with STOCK Merc engines then ALL drives should be RECALLED and the parts should be replaced no matter what kind of power! If the parts are defective then they are DEFECTIVE PERIOD! What a JOKE!
