Removing Skeg on Drive
Old 04-23-2003 | 10:19 AM
BAJA WILL's Avatar
Registered User
Default Removing Skeg on Drive
I read on another thread that, on a triple set up the Mfg had removed the Skeg from the bottom of the middle drive to reduce drag.
Just a thought but what if some one was to do this on a twin set up or even a single? I am sure it would reduce drag but, how much control would you loose?? Verse speed increase??Or has anyone done this??
WILL
BAJA WILL is offline
Old 04-23-2003 | 10:38 AM
Will,
On a twin application removal of the skeg will result in significant loss of control. On triple set-ups the need for the additional skeg is minimized because the two out skegs an do the work just fine. Additionally, the forces placed on the center drive or exorbanent and can lead to premature drive fatigue.
Shane is offline
Old 04-23-2003 | 10:42 AM
dhlaw's Avatar
There is a 47 Outerlimits floating around with triples and the center skeg is ground off. Check www.irggroup.com to place a bid on this repo boat.
dhlaw is offline
Old 04-23-2003 | 10:43 AM
LapseofReason's Avatar
I'am pretty sure if you remove it on a single you will die or be hurt .
LapseofReason is offline
Old 04-23-2003 | 12:15 PM
searace
Lapse... LMAO..
Removing the skeg/ rudder/ vertical plane will
1. significantly reduce steerage, especially when coasting off plane.
2. reduce the water tracking which is what makes a propeller effecient. In other words, the more perpendicular certain props are to the flow of water that runs through them, the more effecient they are....
Old 04-23-2003 | 12:19 PM
Default Tag Police=Skeg Police
The govenment agents that used to arrest you for ripping the tags off of mattresses and pillows are now areesting unsuspecting boaters for grinding of skegs.
Remember, if the skeg fits... don't wear it down.
Wannabe
wannabe is offline
Old 04-23-2003 | 12:22 PM
I drove a 19' bow rider with no skeg....once.....steered great, didn't notice a thing until.......a turn on plane. Felt like the rear tires of a car hitting ice....
Shah Mat is offline
Old 04-23-2003 | 12:26 PM
BAJA WILL's Avatar
Registered User
Shah Mat I knew their had to be someone who had driven a boat with no Skeg
Will
Old 04-23-2003 | 01:21 PM
OBNOXUS21's Avatar
One very reputable racer told me I could take them off my twin engine set up and gain a couple mph in the process, but handling wouldn't be great, so I didn't do it!
Makes sense on a triple set up though.
OBNOXUS21 is offline
Old 04-23-2003 | 03:05 PM
I Have Seen People Drive Up A Boat Ramp And Loose There Skeg........... Control??? They Sure Hit The Brake When They Figure Out What The Noise Is..............
neu-rich is offline
