Mercury Outboard Help...?
Old 05-29-2003 | 08:48 PM
RSCHAP1's Avatar
Default Mercury Outboard Help...?
Just purchased a pontoon with a lil' 40 hp Merc. 1990- Wondering if any of the Outboard Guys on here have a good source for repair info. on one of these. Any helpful sites, manuals, etc.??? I know it needs a stator for the charging system and a tune-up, any help would be appreciated! Thanks!
RSCHAP1 is offline
Old 05-29-2003 | 09:59 PM
Too slow
check out www.screamandfly.com
Old 05-30-2003 | 09:03 PM
riskybusiness
RS:
I'm not as familiar with acquiring parts online for your OB, I'm sure there are sources. As Slow said, hit screamandfly.com.
Personally, I'd get a good ol' printed manual (and new stator, if really necessary) from a dealer.
If you're doin' the work yourself, on a workbench (or whatever), it's nice to have the paper manual as a reference (a medium which tolerates the grease, and whatnot) as easy access.
Who told you it needed a stator (although that is the likely cause of a charging problem)?
Old 05-31-2003 | 12:00 AM
mcollinstn's Avatar
Doubt it needs a charging stator. Most likely just a rectifier. Those buddies will blow anytime you disconnect the battery while the motor is running unless there is a decent 12v load at the time (a short or bad battery connection can also blow the rectifier).
Your local boat store will have a clymer manual for your motor. Fairly rugged little motor.
mcollinstn is offline
Old 05-31-2003 | 01:23 AM
riskybusiness
Clymer will do (better than nothin').....But if you wan the real deal, get a factory manual from your local dealer.
Old 05-31-2003 | 05:55 AM
sterndrivespec's Avatar
we are also a mercury outboard service center.i can give you the oso discount on parts,chris
sterndrivespec is offline
Old 05-31-2003 | 08:14 AM
RSCHAP1's Avatar
Default THanks
Thanks for the feedback. The former owners had a "mechanic" all lined up to do do $900 worth of repairs. I found out he was going top replace the stator for that amount. I had the price knocked down and bought the boat "as is", hoping I could get it fixed cheaper or do it myself. I found a SELOC manual on E-Bay for these, anybody ever heard of those??? I'll dig a little deeper (into the rectifier)before I go out and get a stator-all my local dealers say this size and year motor have a pretty good failure rate for stators(?) Thanks Again!!!
RSCHAP1 is offline
Old 05-31-2003 | 08:28 AM
Hey RSCHAP1,
I got one of those SELOC manuels for a present, I use it to do work on my Merc 200's. It's a pretty good source of info. Good luck on your project!!!!!!
Gassticks is offline
Old 05-31-2003 | 08:40 AM
IRONMAN's Avatar
The rectifier usually goes first usually after someone had connected the battery backwards. most manuals will give good test procedures for all but the ignition switchbox and coils.Overtons or west marine have the rectifiers at a reasonable cost, not orig. merc though. good luck.
IRONMAN is offline
Old 05-31-2003 | 11:54 AM
RSCHAP1's Avatar
Thanks once again-alot further along already than what I was-THANKS
RSCHAP1 is offline
OSO News
Offshoreonly Industry News
0
01-21-2008 07:50 PM
boatme
06-18-2007 09:08 PM
CJC
05-14-2003 10:41 AM
timucin
02-28-2003 06:42 AM
