HELP ! I need stainless exhaust pipe quick !! >
Old 06-26-2003 | 12:07 PM
Exclamation HELP ! I need stainless exhaust pipe quick !!
I need an odd size . It has to be 3 1/2" INSIDE DIAMETER !. 1/8" wall thickness (or thinner),which would make it 3 3/4" Outside diameter . AND , it has to be 316L grade . I am pretty sure thats what marine exhaust is made of .
I need a bout 2 feet real bad ! Machine shop is making me some peices and I can't get a small peice . Smaller then 20 FEET ! Yes , I tried Penn Stainless but they don't stock it and would have to order 20'.
Does anybody have an old tail pipe around that size ? OR know where I can get it for sure .
HHEEEELLLLLLPPPPPP !!!!!
boot is offline
Old 06-26-2003 | 04:00 PM
Hey boot,
try calling Jopeph Fazzio Inc in Glassboro. They are a fairly large supplier and deal in a variety of closeouts too - inventory is always changing. They deal in alot of metals and have a great variety of misc sizes. I've used them before for stainless and aluminum and they just charge by the lb. Not sure if they have an inventory of the tubing in stock, but its worth a call.
856-881-3185
good luck
Lou
pantera38 is offline
Old 06-26-2003 | 04:07 PM
Try; Lake Precision Welding
7701 Cryle Road Unit F
Concord, Ohio 44077
Ph. #440-639-1444 Ask for Bob
Good Luck....that sounds like an uncommon size.....Fred
fred is offline
Old 06-26-2003 | 05:45 PM
Thanks guys ! I'll look into these . This size is common but not usualy availible in small ammounts . They want me to buy 20 feet . I need 2 !
Dave,(wirlwind) just called me and I might just buy his tail pipes and CHOP THEM ALL UP !!! Thanks Dave ! Let me know exact sizes when you can .
Thanks ,Joe
908-782-0688
boot is offline
Old 06-26-2003 | 07:08 PM
Mbam's Avatar
Offshoreonly Advertiser
Boot, I can have it made for you, but are you sure that is the exact size you need? Tubing is normally an OD size, so 3" tubing will be 3" OD etc. Is this a wet tail pipe? If so you can use 304 for what you are doing,
Mbam is offline
Old 06-26-2003 | 10:11 PM
Hi Marc ! Glad to see your still around ! 304 will work ? I will call you tomorrow (Friday ) Are you there then ? What time is good ? I would like to ask your opinion on what I am doing . MAybe you have a better idea . Thanks , JOE
boot is offline
Old 06-27-2003 | 05:39 AM
Mbam's Avatar
Joe, after 9:00 (get there much earlier but the phones are in night mode until then)
954 545 8681
Mbam is offline
Old 06-27-2003 | 12:46 PM
muffman's Avatar
Smile stainless exhaust pipe
Hey if you only need 2ft sections try your local exhaust shop. I I carry ss tips that are 24 inches long from 3inch to 5inch . Or you could try a Truck dealer like Ford, International, Peterbuilt etc. They should carry the ss stacks. They are easily cut with a sawsall
Alex
muffman is offline
Old 06-27-2003 | 03:52 PM
ForrestC's Avatar
Boot, you have a PM.
ForrestC is offline
Old 06-27-2003 | 04:04 PM
BruceK's Avatar
I may have a piece...I will check when I get home to confirm.
BruceK is offline
