Pulse Drives. Anybody using them on a 35' or larger?
any update on this?
imongo, how does the exhaust vent? looking at the slide show on the site it doesnt look like there where any holes cut for exhaust... ???
and with manuverabiltiy....how does it compare to outdrives? i can see the switching of forward and reverse when turning the boat should stay the same but with the props being fixed and just the rudders doing the turning hows it react?
Oh and one last question......i know with the pulse the props are shallower......but how about the draft of the whole assembly? i mean those rudders look to drop down deep.....
thanks
thanks
-Wally
-Wally
iggy, i do know about the whole unit trimming up and down....but its only a few inches from what i understand. (or so i remember reading someplace) But the thing is....the whole unit hangs father off the back of the boat.....thus when the boat sits in the water its draft with the rudders would be deeper. Look at the pic of Doc's boat below......it looks to me like the rudders are about the same depth as the drive would have been......ok maybe a little shorter.......but since they have been moved back some it makes them sit deeper...think about it. Maybe i'm looking at it wrong?
-Wally
-Wally
Also the exhaust can be routed ito the swimm platform. Then it exits under water at idle speeds and aove water when up on plane. I believe Imongo and Doc Santiago both kept the stock thru hull eshaust.
SS930, click on the Pulsed drive link here on OSO. It is a surfacing drive that can be trimed up and down. It turns with a rudder that is directly behind the prop. Makes low speed handling ( foreward and reverse) very good.
SS930, the pulse drive is a surface drive... you can check them out at www.pulsedrive.net
-Wally
-Wally
Terry, How is it going???? Powerplay has a 38' with Yanmars 440's Pulse drives, 78 MPH out of the box! I don't know how it's doing though, it was delivered back in April. I will try and find out more info! Blue Skies, Robbie
DEFY'N GRAVITY
I don't believe the Yanmar Powerplay was a Pulse Drive boat. We have done a number of gas Powerplays that do run great.
30% of our world wide sales are with Yanmars, they have a great power to weight ratio.
The drives trim a total of 6 degrees
