Wanted: Set of speedmaster props
Anyone have a set of 16 or 17 x 24,25,26 etc? Can be 3 or 4 blade 19 spline 6 inch hub for number 3 speedmaster.
Check with John Tomlinson @ TNT. 305-931-3157
I have some,
954 545 8681 |
Believe it or not...there was a PAIR on ebay the other week. Went for $250.
I have a pair in mint condition....three blade for a speedmaster drive...small shaft....17.5X28...just e-mail me if you are [email protected]
DMan |
I need some too,I've been trying to find some 17.5x31 or even 32s with small shafts,and haven't had any luck.
Ken:
I know you want a 6 inch hub, but don't worry about going to the short hub. I had a pair of bronze or brass (I forget which) spacers fabricated to go on behind the prop and in front of the nut so I could try a pair of 3-blades. Works fine. It was only about $40 to have them made. Not fre, but considering the 3-blade props cost about 1/3 as much as the 4-blades, it is cheap enough just to try a pair out. P.S. -- Still had to go with the 4-blades.:rolleyes: |
| All times are GMT -5. The time now is 03:38 PM. |
