New to "go-fast" boats, question about Baja
I have never met a boat I did not like. They all have positives and negatives.
It is a matter of personal choice. As long as you are on the water going fast and making noise, who cares.
By the way,
"Baja Rules".
By the way,
"Baja Rules".
Originally posted by formulaF302
Hey Russ....I'm running an 86 f302 that feel like a heavy pig with the mirage plus 25 pitch props (thru TRS drives). Do you think I should consider a 4 blade? What differnce did you notice? Thanks.. Glenn
Glenn, my 89' 311 SR1 came with Mirage props. I swapped over to the Hydromotive Quad IV's (Mirage were 23 inch pitch, Quad IV's are 24 inch pitch) and I gained a solid 5 mph on the gps at 3200 rpm and 3 mph on the top end. The guys at Hydromotive told me what I could expect and they were right on. In their brochure one of their test boats is a 302 and I think they got an even bigger difference. They really took their time and explained why I would see the difference. Another advantage is that "Outlaw" just jumps up on plane. Much noticably quicker than with the Mirage. Hell, even my wife noticed that difference. I'd definitely give them a call, could be the cheapest speed increase you'll ever get. It certainly was mine. Keep me posted on your results, I'm in the Formula owners forum all the time.
I'll keep checking.
I'll keep checking.
Monty,
I just went from a 24 Outlaw to a 342 Boss this spring. During that search (6 months) I was almost convinced I wanted a Cig. That was until I really did an HONEST cost/benefit evaluation. Baja's are a great value with staying power on the water as well as in the market.
Bruce...
Bruce...
I have a saying..." There is always someone faster, there are those who pay a lot more for their boats, the rest can try reading my transom in 4 footers". I've owned 2 32' bajas "outlaw" style 86' and 94' which have the same hull as the 33'.
Baja is very stable and forgiving. Lots of freeboard and cockpit space. I love my 1994 32 caliper. You can probably find one in the 45k range. the 1990-1997 "magnum, Caliber, outlaw" are all basically the same.
Make sure you get 454 or 502 magnum EFI. This will go 70 with the 454 mag EFI or 75 with the 502.
As with any boat take it to a good MECHANIC to check the engines and SOMEBODY WHO WORKS on them to check the stringers and transom.
I haven't met too many surveyors who are worth the paper they write on.
Monty,
Bruce...
I don't know if I would go that far, Not that Baja's are bad but they don't hold there value like a Cig and for the long term the Cig will hold together better.
My uncle has a 29 outlaw he loves the boat.
Bruce...
Baja's aren't the best, but they are GOOD boats. Mine is a 1990 210 Sport and it runs in the upper 90's on a stock bottom. I am impressed with its ability to run 97 or 98 MPH with pretty good control. Oh ya there are no stress cracks on my boat anywhere.
Nothing like blowing by some new custom boat and having 30 or so MPH on them for about 1/3 the cost!!
