Bravo one to ss = -4mph?
Old 08-21-2003 | 10:29 PM
John B's Avatar
OK, Bravo 1 to Bravo 1 sportmaster lowers. Uppers are the same as before 1.36 XZ's. The lowers were bought empty and my XZ large prop shafts and gears were installed with new bearings by a Mercury facility.
Props tried B1 34's labbed without diffuser, B1 35's labbed with diffuser, and 33 Q5's labbed without diffuser ring.
The rev limiter was moved to 5700 two years ago.
Too much drag...most likely. I can't believe I am the first one to learn this.
John B is offline
Old 08-22-2003 | 11:03 AM
Default Sportmaster Lowers
John,
It is surprising that the Sportmasters are slower at 110+ mph than the std. Bravo lower at the same "X". From what I have learned in back to back comparisons, the Sportmaster lower unit is 1 to 1-1/2 mph slower than the IMCO unit at the same x dimension ( Two cat's and one "V" ). These comparisons were at 105 - 115 mph. Most opinions related to the speed difference were skeg length or thickness. I wonder if the water pick up design on the Sportmaster vs. the IMCO or the std. Bravo unit is causing a decrease. As there is a chance that the speed loss is related to this, maybe you can temporarily plug a few Sportmaster water pick-up slots for a test.
Could you have a temporary loss of HP that is effecting the test results?
If you need your 1/2" spacers back, I not using them... Remember, it's all about the hunt.
Good hunting,
Sprague
BenPerfected is offline
Old 08-22-2003 | 12:51 PM
Quit foolin' around with that old cat, buy a Magnum and start enjoying boating again. See you on the lake.
27sedan is offline
Old 08-22-2003 | 08:16 PM
John B's Avatar
Sprague, Anything is possible. I have waited until I tried half a dozen different days (temperature & humidity), loads, and tried all my props before this post. I am hoping to find someone with similar experiences before I start hacking away at Mercury's engineering marvel.
Bob, I hung upside down in your bilge for 5 years trying to run 80. Now I can sleep between my engines and get depressed if I only run 100.
John B is offline
Old 08-23-2003 | 11:28 AM
Turbojack's Avatar
Love the quote!!!
Everytime I think about doing something else to my boat I am told by friend "That change should only be good for a 4 or 5 mph lose"
Turbojack is offline
Old 08-24-2003 | 03:11 PM
John B's Avatar
I just found out Mercury sportmasters have (TWO) different styles of water pickups on these drives; a long system that the std. flush kit doesn't work on and a newer shorter style that the flush kit covers. I have the long style. Does anyone know what is up with this deal?
John B is offline
Old 08-25-2003 | 09:10 AM
dadinator
Appreciate your info on "things that don't work". I'm in the middle of a lab prop adventure that resulted in a negative 3mph. Labbers response was, "what happen to your engines?"
Old 08-25-2003 | 09:35 AM
Curt
Originally posted by rpm
If you went from Bravo's to #6's at the same x dimension, you need to raise the x dimension. #6's are designed to run higher.
How do you just "raise an X dimension"? Isn't it set from the factory based on the length of the drive lower casing and where the drive is mounted to the transom? What am I missing? I know with outboards you use a jack plate to accomplish this but that can't be done with inboard/outboards rigs...can it? I thought the only way to adjust the X dimension once you get the boat from the factory is by installing a shorter lower casing.
Old 08-25-2003 | 06:03 PM
John B's Avatar
Curt, This boat has Stellings boxes (drive extenders), which allow the drives to be raised or lowered 2 inches, without redoing the transom. Now I can go up or down 1 inch without to much trouble.
Has anyone sharpened the skeg on these sportmasters yet?
How about the water pick-up changes Mercury made?
John B is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
wd833
8
10-02-2003 02:41 PM
