Best Props for 38 Top Gun
Old 09-08-2003, 11:48 AM
Enjoy the show
Ron P's Avatar
Default Best Props for 38 Top Gun
A month or so ago I mentioned my neighbor was looking for a used Top Gun. Well he finally bought one this weekend. A 2000 non step with HP500 EFIs.
The only problem are the props. Seems the current 28s only let the motors go to 4700rpms for a speed of 70.
What are the best props for this hull and engine package and how fast should it go?
Thanks.
Ron P is offline
Old 09-08-2003, 12:42 PM
throttleup's Avatar
Ron,
It was nice speaking with you. I think that using our test props will certainly be advantagous in exploring different prop options. It would also be helpful if I knew whether the props are stock or labbed. Of course this will assist us with determining the appropriate pitch.
Thank you for your time!
Julie
Throttle Up Propellers
877-842-6855
throttleup is offline
Old 09-08-2003, 01:14 PM
Havasu Cig's Avatar
I am using labbed 28's on our T/S Gun with 500 efi's, so those 28's on a non-stepped hull are definitely to much.
BTW: With the 28's I am seeing 5000 rpm's in 105-120 degree heat in Havasu, and can hit the limiters (5250) here in San Diego with the cooler temps.
With labbed 30's I run at about 5000 rpm's in san Diego. I would think dropping down to some 26's would probably work. I think the general rule of thumb is about 200 rpm's gained / lost per inch of pitch up or down.
On our props once we got the rpm's close, we had them work on the cup to dial them in. Took three times back to the prop shop on our 28's.
Good luck.
Havasu Cig is offline
Old 09-08-2003, 01:24 PM
Enjoy the show
Ron P's Avatar
Cig, what speeds are you getting?
Ron P is offline
Old 09-08-2003, 01:36 PM
Pacificlink
On my 1996 Top Gun with 2002 500 efi's I ran 4 Blade 26's
Old 09-08-2003, 01:57 PM
diamonddaveF170
Ron,
Call me for prop info.
Dave
Diamond Dave Offshore Racing
732-549-1800 #work
732-321-0345 # Home
I have three sets of props all labbed by Rolla and custom done for my Gladiator wth twin 500's
Just for the record we saw 90+ on GPS in NYC Race
Old 09-08-2003, 02:19 PM
Havasu Cig's Avatar
Since the props were dialed in the best I saw was 79.9 @ 5000 rpm's in Havasu, about 100 gallons of fuel, air temp was 103.
I should be able to add a couple miles an hour to that in salt water and at lower temps.
liquid prozac
Cigarette
9
05-16-2008 06:51 AM
hangem out 2dry
Prop Talk
2
03-11-2008 09:52 PM
seahawk
Cigarette
6
07-24-2006 05:53 PM
seahawk
Prop Talk
16
07-13-2006 05:19 PM
M39976
Cigarette
15
01-21-2004 11:11 PM
Quick Reply: Best Props for 38 Top Gun
