Pro's & Con's between full tunnels and tunnels with center pods
Super t, take a look at several single engine sub 30 foot cats,the center pod is as deep as the outside sponsons. My buddies 25 talon looks like a tricycle from the stern where as my daytona's pod is about 6 inches shallower. The Howard cat is another I have seen with a very deep pod.
Cord,how deep is the pod on your FireHawk?
Marty, I'm not saying that cats have anything to do with the venturi effect. It was just an example to illustrate how a difference in height affects air flow. Like that center board on F1 cars disturbs the venturi effect, a center pod will disturb the air flow and the air cushion in cats. I still maintain that a center pod will decrease lift as it is much easier to create a constant air cushion with a flat surface, ie. without the center pod. But true, I work with V bottoms only and I am not a cat specialist really. It would be nice to hear from someone who has some real experience and not only theoretical banter...
Hey Marty, that was not aimed at you. It was aimed at none other than myself. No reason to get excited as I am the first one to admit that if I have some theoretical knowledge about those things, I do not have any real experience in designing or building those things. So let's keep it friendly. But this illustrates pretty well why some designers swear by center pods and others say they are detrimental. I think we all agree that a center pod does have an effect on the air flow and the cushion under the boat. It has positive and negative effects. What the net result is, positive or negative, is where opinions diverge...
Official OSO boat whore
At least 1-1/2" deeper than the outer sponsons.
ST, no problem. One day let's share a pitcher of beer.
Interesting the firehawk center pod is deeper than the sponsons. Sortof like a V bottom with slots cut in. I wonder what the back end looks like at speed- Does it ride on the center pod and chine walk back and forth or does it lean in in the turns like a V?
The Eliminator at speed probably the center pod is up out of the water. A video of the rear of these boats at speed would be great.
