Surface Drive Gif
Old 11-21-2003 | 07:34 PM
SS930's Avatar
Nice work Ernie, very impressive!
I hope someone isn't already splashing it.
SS930 is offline
Old 11-21-2003 | 10:04 PM
wwwTOPDJcom's Avatar
Ernie you using Mech desktop?
I have all the current ACAD Arch desktop 3.3
and ACAD 2004 does Mech desktop have more tools
for making the machine parts?
wwwTOPDJcom is offline
Old 11-21-2003 | 10:40 PM
Check out this picture. You can see the surface drive that you designed in action at the website
N2Speed Website
IHTFP is offline
Old 11-22-2003 | 07:52 AM
KILLER VIDEOS
open87 is offline
Old 11-22-2003 | 08:17 AM
I called the guy at N2Speed about these surface drives. He makes them himself and they are very $$$$. The rudder is titanium.
IHTFP is offline
Old 11-22-2003 | 09:41 AM
mcollinstn's Avatar
I prefer the N2's trim cylinder mounting location.
Top, your tapered housing doesn't appear to have adequate diameter on the "prop end" for the appropriate size of thrust bearing packs.
mcollinstn is offline
Old 11-22-2003 | 03:37 PM
TopSpin80's Avatar
My design was done for fun and is not meant to be functional... it is a tool for learning
CAD and I thought I would atleast design something that I liked. But since you guys are getting all technical I guess I'll have to design one that will work. I can't believe with all these critiques that you guys have not noticed the props concave the wrong way.
Oh and I use autoCAD 2002 I don't know much about any other design programs.
Ernie
TopSpin80 is offline
Old 11-22-2003 | 09:33 PM
mcollinstn's Avatar
course we noticed the props.
not trying to send a catalog of imperfections, only significant design conflicts.
and if you didn't want it critiqued, then you sent it to the wrong place.
2002? Bless your heart. You're spending a lot of time stitching together those 3D entities using that set of tools. Mech Desktop is a big improvement (but is still lacking in many ways). BUT, the goodpart is you are learning the 3D work from the bottom level and you will be a better draftsman because of it. When you get a powerful set of tools to use, you will be able to understand them and adopt them very quickly.
Now let's get some thrust bearings on that propshaft...
Old 11-26-2003 | 08:35 AM
TopSpin80's Avatar
I haven't had much spare time this week but here are the newest creations. Another drive in 3D this one has more accurate measurements, bearings, and a u-joint that is built from dimensions of a real one. Stainless u joint 1.5" shaft size that takes 55000 inlb torque at 35deg max angle. that is 4583.33 and these guys are testing brake torque. If you don't understand that it means this little u joint will handle just about any powerplant you feed it.
Ernie
Old 11-26-2003 | 08:42 AM
TopSpin80's Avatar
No pic posting today. site isn't working right. does any one have the .dwg files for merc engines and stern drives? They are needed for my boat drawings and I can't find them.
Ernie
