-   -   Now this is a pull truck.... (https://www.offshoreonly.com/forums/general-boating-discussion/64566-now-pull-truck.html)
Pure Energy 11-24-2003 09:08 PM
1 Attachment(s)
[QUOTE]Originally posted by SummerObsession
[B]A little OT here, but does ...cough...wheez...FORD...there I said it....make a short box dually 1 Ton 4x4?
Yes, they do
:D
BigSilverCat 11-24-2003 09:20 PM
the truck i used to pull my boat with was a 2001 crew cab dually f350 it weighed 8800 lbs and at mokan drag way it ran a 13.9 spinning the tires through the 60 ft mark. I had a 150hp chip alot of propane and nitrous and many little tricks. And you wondered why I went through several transmisions.
MitchStellin 11-24-2003 09:33 PM
Thats why he came off the line slow, he knew he would grenade his transmission or at least spin his tires the whole way.:D
R Addiction 11-24-2003 09:41 PM
That is some cool stuff!!!:cool:
Aqua-Holic 11-24-2003 10:20 PM
slingshot beat me to it.....12V cummins, twin turbo
Wally 11-25-2003 09:21 AM
Originally posted by SLINGSHOT
Richard: 1995 F350 XLT 4X4 CC LB SRW Built E4OD by BTS with Baumannator controler. 12 valve Cummins with ported head, Piers race pump & Camshaft, 370 injectors, twin turbos@ 95psi boost 800 rwhp on #2 only 4.10's, Detroit locker, 36" PJ dirtgrips.
:eek: 95spi boost!?!?!?!? SAY WHAT!!!! :eek: i hope thats a typo cause i cant see the engine handling that!!! i think the head bolts would be stretching and floating on the block!!! :eek:
Caincando1 11-25-2003 12:44 PM
That is great! All the ford fans jumping on the band wagon and it's got a cummins in it. :p And a 12 valver at that.
I see it's got a Piers pump. I've read allot of good things about Piers Diesel Research.
Brian
Cord 11-25-2003 12:56 PM
I suppose it's possible. I'm hanging right around 300hp and I peg the 35psi boost gauge. However, how does a (Ford?) electronic trans work behind a mechanical cummins?
open87 11-25-2003 06:02 PM
95 psi:eek: 36' tires. hooked up:crazy: that has got to be the baddest 350 on the road. that guy has to have a blast driving that truck. that is the ULTIMATE SLEEPER!!!!!:D :crazy: :crazy: :D
Waterfoul 11-25-2003 07:40 PM
Good Grief!!! An 11.42 at 118 mph!!!!! Left that Mazda (I think it was a mazda) in his smoke. And there was a LOT of smoke.
