Pulling 45' Sonic with Excusion ,NJ to FL. Any thoughts ?
#52
Originally posted by boot
looney toon , To do it right , at least a HEAVY DUTY 3/4-1 ton truck . Single wheel would work OK if the trailer is set up right . Make sure what ever truck you get has the heavy duty packages on it . They all say they do ,but make sure they show you on paper . Like many have stated , legaly you need to watch what the truck is rated to carry .But most trucks will do .
#56
Originally posted by RedDog382
Mad Cow,
What part of Florida will you be in and when are you leaving? I'll be in Tampa and then the keys after Christmas. Give me a call ... maybe we can hook up down there.
Mad Cow,
#57
.I thought I saw 14,000 some where
#58
Charter Member#203
get a couple of quotes , there are several companies that can and will handle that boat, have the equipment and are insured. deep Lagoon/Page racing is one
#239-481-6414. drivers are cdl as well.
#60
Hey,
I pulled a 43 Black Thunder with my 2500 suburban with the 8100 Vortec and a 410 rears, Evan though the truck was rated at 15000 lb. compacity, The motor was not the problom, Across the alley in Fla, Boat started bouncing and folded the stock hitch and rear of frame under, Real scarry feeling at about 60MPH, Definetly upgrade the Hitch and brake pads, Neadless to say, I now have a new dulley, I would never try that trip, as hine site is 20/20 , Just my opinion....
Good luck....
Good luck....
YOu KNOW mine won't be ready !
