Need help identifying these steering cylinders from TRS set up . >
Old 12-03-2003 | 10:09 AM
Default Need help identifying these steering cylinders from TRS set up .
These are from a 1983 40' Excalibur hawk with TRS drives . They are in bad shape and need to be replaced .They are the steering cylinders not trim . They look a lot like the trim cylinders but shorter and a different end and mount. The trim cylinder says Mercury or mercruiser, or something on it but the steering doesn't . Can anyone tell me what they are , who made them , and who has one ? One is not bad , the other is eaten through by the mount and would snap right off.
Attached Thumbnails Need help identifying these steering cylinders from TRS set up .-dscf0001-2.jpg
boot is offline
Old 12-03-2003 | 10:10 AM
Attached Thumbnails Need help identifying these steering cylinders from TRS set up .-dscf0002-2.jpg
boot is offline
Old 12-03-2003 | 10:11 AM
Attached Thumbnails Need help identifying these steering cylinders from TRS set up .-dscf0003-2.jpg
boot is offline
Old 12-03-2003 | 10:12 AM
last
Attached Thumbnails Need help identifying these steering cylinders from TRS set up .-dscf0004.jpg
boot is offline
Old 12-03-2003 | 10:19 AM
well , 1 more
Attached Thumbnails Need help identifying these steering cylinders from TRS set up .-dscf0005.jpg
boot is offline
Old 12-03-2003 | 11:12 AM
Doller Offshore
Hi Boot, Those are the old Mercury set-up. You probably would want to replace that, it is old, aluminum.
We do not have any.
I would suggest you look for some used stuff, or give us a call and we can give you some options on new.
Good luck, Mindi
Old 12-03-2003 | 12:04 PM
Jolley's Avatar
Maxx or Alfster can make you up some brand new ones to you size and type. They have had glowing reviews so far !
Jolley is offline
Old 12-03-2003 | 01:05 PM
Thanks Mindi ! Your always there ! I should just call you evertime I have a question !
Jolley ,Thanks . I saw something about them . Looked nice . I'll lookinto that too . Joe
boot is offline
Old 12-03-2003 | 02:41 PM
lucy's Avatar
go mindi . its not a boys club anymore!!!!!!!!!!!
cya lucy...................
lucy is offline
Old 12-03-2003 | 03:01 PM
JUSTONCE's Avatar
for what you will pay for new ones in good shape I'd consider switching to external hyd. steering my.02
JUSTONCE is offline
