Herring Skegs For # 6's
Old 12-16-2003, 07:15 PM
Default Herring Skegs For # 6's
WHO INSTALLS THEM......PRICE.....DRAWBACKS
SLINGSHOT is offline
Old 12-17-2003, 07:32 AM
outer42's Avatar
I don't knoe who installs them,but have them on my boat. I'll call mike if you want. make me a offer and you'll have them already.
outer42 is offline
Old 12-17-2003, 09:01 AM
I would call Herring as a start. I do not know the advantages but they are a pain to repair. They have had a lot of weld added and the edges are very very thin. This makes weld repair difficult. But they can be repaired. For myself, I would have a hard time allowing that much welding to be done on such an expensive piece. Aluminum does take well to that much heat it tends to soften the casting. But I am sure there are people who know better than me.
mmwalters is offline
Old 12-17-2003, 09:04 AM
are you going to saw zall them off the bottom of your drives or do i get to do that?
Old 12-17-2003, 09:05 AM
one of my skegs is fcked as is the others are avg...do you have a # for herring
Old 12-17-2003, 09:06 AM
TNT sells and installs them and also does dry sump conversions. Talk with Johnny T. The only negative I've heard (not from JT) was that the machining of the case to accommodate the Hering "might" weaken the lower case.
That "might" wouldn't stop me from doing the mod.
I want to add them to my 6's because hi-speed handling is improved ( per JT).
PS: has anyone heard about the dry sump 6's having a problem with the internals rusting? Especially if the drives are unused for a period of time.
Due
Dueclaws is offline
Old 12-17-2003, 03:26 PM
KiloKat
KiloKat's Avatar
I used them on my 36 pleasure Skater that ran 180+. Worked great but didn't look too good unless you buffed them regularly after each use. But, that was before the current Mercury lower design, which is basically a copy of the Herring skag. JT at TNT can help you with this if you like. His number is 305-931-3157.
Everything Runs Better On Alcohol
www.nautiboats.com
KiloKat is offline
Old 12-17-2003, 03:30 PM
Charter Mod
BLee's Avatar
Thumbs up
GOD [email protected]#%&!!! A 36 that does 180+!!!!!
David you define "the need for speed."
AWESOME
BLee is offline
Old 12-17-2003, 04:09 PM
They do look like you %$^*&# up your skegs and had them repaired but they are still a couple of miles an hour faster on cats over the new Mercury skeg.
salesmanship is offline
Old 12-17-2003, 06:21 PM
What is Herings web site address?
MarkC is offline
Quick Reply: Herring Skegs For # 6's
OSO Sponsor
OSO Advertiser
OSO Advertiser
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
OSO Advertiser
