World's FASTEST.....
Here's an earlier record holder...to give you an idea of how a really maxed boat should look. When horsepower is not a function of checkbook size..... you need a LOT more engineering and driving skill to go fast.
T2x
T2x
Originally posted by glassdave
that is smokin
. Rich do you have a pic of that type of boat by any chance? just curious as im not to familiar with boats outside offshore types. thanks
that is smokin
Here is a photo of the record setting hull that hangs in the Race Roce Cage in Orlando..
T2x
T2x
There is a formula I use to compute air entrapment psi vs tunnell compression ratio which in turn gives me an idea when any weight of cat will want to fly. You have to begin using negative trim on stern drive (transom mount) boats before this speed. Shaft drive boats are entirely different because their thrust is at the keel which in turn tends to push the nose of the boat over more, ie - shaft drive boats are safer at highest speeds.
I maintain the fastest design concept extant...is the 4 point ram WING.......pictured below.
T2x
Originally posted by sutphen30
i saw the same thing,i wonder if flying the hull was the plan.looks awesome
T2x
Basically a hydro is a faster design than a cat because the drive is set up (trimmed under) in such a way as to lift the stern out of the water completely at speed and "prop ride"
Absolutely correct but my comments had to do with the reason for negative trim used in the pictures above and not which style hull is the fastest. However, I tend to agree with your comment about the 4 point ram wing. Who knows, maybe we'll see an entirely new concept design incorporated into an offshore catamaran hull in the future that will utilize the best of both worlds ...
That's something we can certainly agree on........
If only the damn things ran in rough water
T2x
