Question regarding wireless routers
I install a wireless router in our house. Ever since, I can not log onto my bank account. Is this due to something with the router? Is there a setup change I need to make to allow access to those sites? What is confusing is that I can log onto Paypal and other secure sites. Any help is appreciated. Thanks.
XP ??
If so go to connections right click and open properties on your wireless connection go to advanced and see if the firewall is turned off if not turn it off and try again.
The Router will act like a firewall (outside connections see it, not your computer). There are other possible problems but this is a good start.
I have Steps & Bubbles!
I tried that and it didn't help. Any other ideas. I can get into my other bank accounts, so I am wondering if it is a problem with the bank's website. If one worked, so all of them work?
Just give me the account # and password I'll give it a try
I would guess that you are right about them having trouble. They should have a Tech help # that will help you out with problems they are having or a Password reset.
If all other web sites are working and other secure sites work I would not change any other settings until you call them.
Since you are now wireless if you travel a lot I would download an automatic wireless sniffer to check for connections outside of your area. XP has a utility that will do this but found BOINGO to work very well and it's a free program that you can turn on and off with no side effects.
Scott,
what mfg did you install? if its Linksys they have a great online support and can help you out. I had the same problem and they fixed mine.
http://www.linksys.com
I was the one with the problems, not Scott. And yes it is a Linksys router. I will give them a call after I find out if it is on my end or on the bank's end. I would hate to waste their time if it is the bank's problem. Thanks for the help.
