built in hooks?
Old 02-12-2004 | 08:27 AM
KH0302's Avatar
Default built in hooks?
Check out this pic. Gary Reagan who works on my boat says SeaRay built these hooks into the chines on purpose to keep the nose down. He thinks grinding them down and re-gelcoating could cop me a couple mph. What do you think?
KH0302 is offline
Old 02-12-2004 | 08:41 AM
mcollinstn's Avatar
can't see what you're talking about.
try a side shot.
mcollinstn is offline
Old 02-12-2004 | 08:46 AM
robyw1's Avatar
It seems like a lot of work for 2 MPH considering that the average human walks at 3.3 MPH.
Happy sanding
Roby
robyw1 is offline
Tantrum's Avatar
That is not a "hook"
Hook is a concave bottom (hull) towards the transom. The running surface is concaved near the transom (front to back) to push the nose down.
Tantrum is offline
Old 02-12-2004 | 08:55 AM
KH0302's Avatar
Ok...then what would you call the center chine which is convexed? See how the left and right ones are flat across, and the center bulges downward? Gary says that's built into the mold(or was)...
KH0302 is offline
Old 02-12-2004 | 08:57 AM
pachangalpina's Avatar
You are not showing the hook in that pic but the Pachanga did come with a hook. If you remove it you have to think about all the additional cost that will be associated after the bottom work is done. You will have to have tabs and a new prop. And find somebody else to do the work.
pachangalpina is offline
Old 02-12-2004 | 09:00 AM
mcollinstn's Avatar
Doesn't matter what "shape" the chines and stuff are from the back as far as hook or rocker, what matters is the amount of change front to back that they go thru in the last 3 feet of hull.
Granted, your hull has some odd looking stuff on it, but without a side shot there is no way to see how it transitions to the rear.
As far as what it is and why they did it? Who knows. There's a lot of odd hulls out now and some features I am convinced are there just to nake them look "hi tech".
A lot of times a change in that area is for spray control or holding tight in a turn or something.
Still need a side shot.
Old 02-12-2004 | 09:08 AM
KH0302's Avatar
pachangalpina check your PMs...
KH0302 is offline
Old 02-12-2004 | 08:09 PM
Ric232
I see, your talking about the area between the strakes. Like mcollinstn said, this is not a "hook" and probably has no effect. Maybe if you got that trailer bunk in the right place it would flatten that spot out for ya'.
01hammer
Baja
0
07-12-2008 08:54 PM
kidapache
Wanted
1
02-27-2008 07:00 AM
TeamSaris
Superboat
12
08-01-2007 01:35 PM
glassdave
General Racing Discussion
2
02-13-2003 08:49 AM
