Custom Rims?
Originally posted by wannabe
When you go to 20"+ you really need to upgrade the brakes (especially for towing). So stay with 18" if you can.
I know this doesn't make sense, but the laws of physics and moving the lever farther out from the centerpoint means more force to overcome.
Wannabe
Wannabe
. It's the overall tire diameter that comes into play. If the wheels are SO big you must increase tire size drastically then you have to worry.
Originally posted by mopower
I'll give you a little hint. Wheel size makes little or no difference
. It's the overall tire diameter that comes into play..
Da boyz in da hood might groove on it, but it'll SUCK! in the winter....
That's what I did too. Also went with 305-70x16 load range E Nitto Terra Grapplers.
Rchev,
Mine are 33". They also had 315 but they where 75's not 70's. The diameter was 35" and I wasn't sure I could get away with it in the front when I turned. Didn't want the grief of lifting. My 350s high enough already
Cap,
It is still being worked on, I went w/ a 2" lift in the front, and the air suspension actually levels the truck off in the rear. I changed the hood, front facia, added a chit load of lights, tint, stereo, gps, tv's.... You know, the usual.
I'll send some pictures when it's done. Had to go with a custom exhaust, because no kit available. True 2 1/2" dual flowmaster system. Sounds Sweeeet!
JM94
03-26-2003 07:44 AM
