Un-invasive GPS Install
Old 02-27-2004 | 07:20 AM
  #31
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thanks GL, thanks a lot!
Sydwayz is offline
Old 02-27-2004 | 10:17 AM
  #32
C_Spray's Avatar
Diamond Member #001
Originally posted by craig223
OUCH!!!! The hole was already there (for the compass)! I'm going to fill it in and start over.
Get a man-sized GPS/chartplotter, and it will completely cover the entire area, including the hole. Loks like it's a pretty big area - 7" square or so. Another alternative is to make up a backing plate and paint it to match your dash/bezels. That way you won't have to try to glass/gel that area back up.
C_Spray is offline
Old 02-27-2004 | 11:17 AM
  #33
OldSchool's Avatar
Chuck,
I got the 182 Color chartplotter which is more than big enough to cover the hole, However, to mount it flush against the dash, I need a hole smaller than what is presently there. My options (that i've come up with) are to glass it in or take some plexiglass or something similar and permanently attach it from the inside and then drill the smaller hole in that. I'm open for suggestions but leaning towards the plexiglass route.
OldSchool is offline
Old 02-27-2004 | 11:24 AM
  #34
OldSchool's Avatar
When completed, it will be similar to this setup. I'm thinking that by doing the backing plate from the inside, it will look a little better.
  #35
dyno's Avatar
Charter Member #655
white lexan is real easy to work with!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 02-27-2004 | 12:42 PM
  #36
OldSchool's Avatar
Does Home Depot sell it? Because I'm going to put in from the inside, It really doesn't matter what color it is.
Craig
Old 02-27-2004 | 01:37 PM
  #37
C_Spray's Avatar
Diamond Member #001
Craig - It's up to you. Your way will work fine, but if you can find a painter, it would look neat to paint the plastic to match the dash and just attach it to the top face of the dash.
What size/thickness do you need? I have some scrap pieces in the garage from my project. If I've got a piece the right size, it's yours for free.
That will be a really clean installation, except it's on the wrong side of the boat. (Unless Nancy's driving...)
C_Spray is offline
Old 02-27-2004 | 01:42 PM
  #38
OldSchool's Avatar
Nancy will be fine.....she will be looking at my handy-dandy map that I gave to her!! It's got the whole bay on it!!!
Old 02-27-2004 | 01:49 PM
  #39
C_Spray's Avatar
Diamond Member #001
That ought to get you within, say.... oh..... I dunno..... maybe 10 miles of where you should be. Good enuf!!
C_Spray is offline
Old 02-27-2004 | 01:50 PM
  #40
OldSchool's Avatar
