-   -   Conduit Clamps (https://www.offshoreonly.com/forums/general-boating-discussion/75334-conduit-clamps.html)
mr_velocity 03-28-2004 08:00 PM
Conduit Clamps
I need to replace the 2 hole straps ( clamps) on 4" electrical conduit that runs down the bulkhead. The galvanized ones the electrician just aren't cutting it. Are the grey pvc clamps OK or should I try and find stainless ones? Stainless is forever but the only clamps I was able to find were $6 each. I need 20 of them.
mcollinstn 03-28-2004 09:11 PM
The plastic ones will get brittle with age. Heat will also shorten their useful life.
If they aren't in a high-stress situation, though, they should work fine.
Why don you need 20 of them? Send pix of area in question.
mr_velocity 03-29-2004 09:33 AM
It's a long run, close to 100'. The conduit runs along the bulkheak just under the top whaler.
ChrisK 03-29-2004 06:01 PM
What is is run in? dang... 100'
boss252 03-29-2004 06:20 PM
I work for an electrical wholesaler. Maybe I can help you out. Give me a call tomorrow at the office 1-800-424-3468. ask for Jeff. I'll give you an OSO discount. :D
mr_velocity 03-30-2004 12:27 PM
Then it turns and runs out to the end of the dock, probably another 100'. It's 4" PVC conduit, carries the power for 8 slips and 3 boat lifts. Each has 30amp service.
Jeff I'll give you a call when I get back from vacation in 2 weeks. Thanks.
boss252 03-30-2004 12:35 PM
Sounds good
ChrisK 03-30-2004 12:36 PM
ahh... got ya.. thought it was a boat you where using it in... now I understand.
Panther 03-30-2004 12:47 PM
Vacation!!!!
Who has time for vacation???? You have work to do on the boats.
mr_velocity 03-30-2004 01:37 PM
Originally posted by Panther
Vacation!!!!
Work, what work? That's what the fall is for. I just need to cut the covers and I'm ready to go. Did get the 14' out this weekend and the Proline. I'll have to post pictures of those nuts, of the 4 only one was whole and even that was cracked on one side. The TRS nuts were a perfect fit, $4.77 a pop. In stock at Freddie's.
When I get back I'll cut the cover on the Whaler. The Velocity will stay wrapped until the 3rd week of May.
Water in the river was a balmy 43 degrees.
