Need Fly Wheel Changed in Miami / Ft. Lauderdale >
Old 03-29-2004, 10:40 AM
animalhouse's Avatar
Default Need Fly Wheel Changed in Miami / Ft. Lauderdale
I need to have a fly wheel changed ASAP. Any Help would be appreciated. Boat is in Ft. Laudeardale, but will Travel. Help!!!!
animalhouse is offline
Old 03-29-2004, 10:56 AM
SummerObsession's Avatar
Call Tres Martin at Martin Offshore:
954-587-1220
They do great work!
He is in Lauderdale.
SummerObsession is offline
Old 03-29-2004, 11:10 AM
Performance Boat Center
Tim G.'s Avatar
Troy at Supreme Marine can make it happen. 954-797-1818. Make sure you tell him Tim G sent you..
See you at the PR this weekend.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 03-29-2004, 11:13 AM
Offshoreonly Advertiser
Mbam's Avatar
Tres is good, but you can also try Steve Lopez, he was the crew chief for DeSantis last year. Just north of Ft Laud in Pompano (he rents half our building from us)
954-816-9598
Mbam is offline
Old 03-29-2004, 11:29 AM
outer42's Avatar
Call J.T at TNT MARINE they service sterling for mike. J.t hooked me up on a key west run with a new drive, i hit the slings and in and out in 45 minutes.
outer42 is offline
Old 03-29-2004, 11:33 AM
Thanks Scott,
J. T. Hooked me up, and is going to fix it in the morning. Be careful of the new little mercury starters, third set out of the box that puked the gear. See you Thursday. First round on me!
Old 03-29-2004, 12:29 PM
outer42's Avatar
I'LL BE IN LATE ON THURSDAY AND DROPPING IN FRIDAY A.M. AND GOING FOR A LITTLE TEST RUN.
outer42 is offline
Old 03-29-2004, 01:58 PM
JimV's Avatar
Animalhouse,
Check to make sure the starter doesn't need shims. I had a similar problem, after adding some shims the problem went away. Say hello to Bob
JimV is offline
Old 03-29-2004, 02:12 PM
Warped & Twisted Member
Jamie B.'s Avatar
Originally posted by JimV
Animalhouse,
I agree, shim it.
Jamie B. is offline
Old 03-30-2004, 09:13 AM
Scott,
I'll be there on Thursday night. I am arriving with the OL boys towing pete's boat down. See you in the boat house.
Quick Reply: Need Fly Wheel Changed in Miami / Ft. Lauderdale
