Bolt tightening
Originally posted by Tinkerer
Solid roller? What were you running before?
What pistons and compression are you running?
taking full advantage of the 110 octane
And running a solid roller, 250/258, .595/.595 lift. computer program gives a idea of about 60-70 hp more then last year. an estimate is around 570 hp.
Big Chevy
Main cap bolt, 396-427 2-bolt 95 ft.-lbs.
Main cap bolt, 396-454 4-bolt (inner/outer) 110 ft.-lbs.
3/8 in. connecting rod bolt 50 ft.-lbs.
7/16 in. connecting rod bolt 67-73 ft.-lbs.
Cylinder head bolts, long 75 ft.-lbs.
Cylinder head bolts, short 65-68 ft.-lbs.
Screw-in rocker arm studs 50 ft.-lbs.
Intake manifold bolts (cast iron head) 25 ft.-lbs.
Oil pump bolt 65 ft.-lbs.
Cam sprocket bolts 20 ft.-lbs.
Harmonic damper bolt 85 ft.-lbs.
Flywheel/flexplate bolts 60 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Bellhousing bolts 25 ft.-lbs.
Exhaust manifold bolts 20 ft.-lbs.
D. Ocean
D. Ocean
NO - I couldn't find the $ this year so I am going with
the new Pro 1 heads tricked out by Jim V.
That and the Hyd Roller cams instead of the sollid flat tappet that I ran last year.
I also 0 decked the blocks and bought a 10 QT Dooley oil pan ( I still need one more - ANYONE GOT ONE)
With the new heads and cams and a slight increase in compression I hope to gain 50 to 75 HP per engine.
I hope to be in the 650 to 670 HP range.
I sure am glad that I can run mid grade in my tub.
I remember the good old days when I had to run 110 in the GLASTRON.
The FAST guys used to follow me all the time and I couldn't figure out why untill I asked one of them.
( THEY LIKED THE SMELL )
It does smell good.. Even my mom likes it
I decked mine to zero so I could use some good gaskets instead of those .015" steel shim gaskets I was using. End of last year those gaskets were blown out in a few places
The cometics should keep everything sealed in
Sounds like you have a great setup for this year, expessically with a set of heads tricked out by jimv. good luck tinker, hoepfully I'll be over this summer and check out your ride some time
Here's an affordable SC 502 for sale on E-Bay:
http://cgi.ebay.com/ebaymotors/ws/eB...category=46098
D. Ocean
Pompano Beach, FLA
D. Ocean
Pompano Beach, FLA
