FORD EXCURSION or F250 advice >
Old 05-03-2004 | 04:50 PM
PMTCHIPS's Avatar
Air Lift Kit
http://www.pmtchips.com/product.asp?...340&dept_id=13
PMTCHIPS is offline
Old 05-03-2004 | 06:09 PM
MitchStellin's Avatar
I have the air bags and a 3"ift, There is nothing better than a level truck and trailer. This is with 60psi.
MitchStellin is offline
Old 05-03-2004 | 07:51 PM
Mr. Demeanor
Originally posted by outlawinil
Mr. Demeanor- where are those rubber spacer blocks? Better measure the thickness of the very bottom spring too.
Do a search on the net for somthing like F250 F350 difference and you will find a bunch of info.
The X's ride nicer so I imagine there are some other diferences with the X.
Old 05-03-2004 | 08:02 PM
TO THE WOOD's Avatar
BUY A CHEVY WITH "AUTORIDE" AND YOUR DONE
TO THE WOOD is offline
Old 05-03-2004 | 09:37 PM
outlawinil's Avatar
Need pulling power
outlawinil is offline
Old 05-03-2004 | 10:12 PM
Mr. Demeanor
Have they put a diesel in the mini van...I mean Suburban yet?
Old 05-03-2004 | 11:05 PM
buck183's Avatar
Originally posted by MYPANTERA28
Buck183 I want the vehicle level when I trailer the boat, for those of you saying go with the air bags is that with a self leveling compressor installed or without.
An Air Bad system can be set up a few different ways depending on needs and budget. You can air them up manually, do an onboard compressor that you adjust to your needs, or do a regulated set up. Nothing wrong with any of them. Just that some are easier to use than others.
If you want to tow a heavier load level than Air Bags it is. I'm putting two sets on this weeks for customers. Money well spent IMO.
Buck
buck183 is offline
Old 05-04-2004 | 01:07 AM
Doin the Air Bag thing with the compresser/in the cab adjustment Wed. on the Ex.
Need to tow the 42 level.
Back4More is offline
Old 05-04-2004 | 02:20 AM
carter38's Avatar
Air bags is the key to towing. Can't go wrong.
carter38 is offline
Old 05-04-2004 | 07:36 AM
Registered User
Thanks everyone
MIAMIBOYZ is offline
