Trailer bearings, WTF!!!!
Old 05-11-2004 | 05:12 AM
cig1988's Avatar
Yeah, those bearings with the plastic cage around the needle bearings are really nice (and cheap). Always make sure the seal is snug on the spindle before installing them on the hub. I bought 6 seals begining last season and was in a rush. Needless to say 1 of the 6 was the wrong one. Although they looked the same it was very decieving.
cig1988 is offline
Old 05-11-2004 | 05:26 AM
blownincome's Avatar
Another way to detect trouble is every time I tow I do a walk around(when I get to the lake or home) and feel the bearing cap temp if one is hotter than the others I know there is trouble brewing..
blownincome is offline
Old 05-16-2004 | 05:12 PM
Hi-Tech Marine's Avatar
Default Re: Trailer bearings, WTF!!!!
Definately check to see you if are installing them to tight or loose.
Hi-Tech Marine is offline
Old 05-16-2004 | 06:52 PM
cuda's Avatar
I fill the posi lubes when I get home every trip. That way it forces any water out then, not letting it sit until the next time I go out.
I had a lot of trouble with my last trailer with the bearings. I wasn't burning them, I was actually breaking the bearings. Change to Timkens and the problem was solved.
cuda is offline
Old 05-16-2004 | 07:44 PM
i switched to merc high pref gear lube with clear caps so you can see if water is in the bearings. i trailer about 100,000 miles a year between five truck and trailers that go in the salt water.
stick1969 is offline
cgarrett
10
05-07-2006 01:51 PM
e8411a
5
05-05-2006 12:33 PM
THRILLSEEKER
2
11-28-2003 10:53 AM
Barrett
09-04-2003 06:48 PM
Waterfoul
05-12-2002 08:00 PM
