Dip Sticks, Where are yours? >
Old 05-12-2004, 06:56 AM
VelocityMark's Avatar
Question Dip Sticks, Where are yours?
I have a new Keith Eichert 10qt. oil pan that came with a straight stainless dip stick that has to be bent into position with a pipe bending tool before located on the block. It is a one shot deal, so I need some advice before I screw it up. On the 675 Eichert motor that runs the same pan you can see it coming out in the front left of the motor right above were the mechanical fuel would be mounted. To do this you would have to come out of the oil pan and make a 90degree bend to get under the motor mount and then work your way through the fuel pump and sea water pump. If someone else has done something else please post a pic. I need other suggestions.
Thanks Mark
VelocityMark is offline
Old 05-12-2004, 07:22 AM
Tonto's Avatar
On the GIL pans, they use flexable tubing and compression fittings on the pan and a adel on the head. If you could swap your stainless tubing for flexable plastic, it might make things alot easier.
Robert
Tonto is offline
Old 05-12-2004, 07:54 AM
Moderator
ChrisK's Avatar
mine is in my pants...
oh wait.. wrong one..
well its a stock merc motor, soooo where most are located
ChrisK is offline
Old 05-12-2004, 08:29 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
I was going to say; "on the other side of the bed in the morning". But since I am single, maybe that is saying something else.
Sydwayz is offline
Old 05-12-2004, 08:48 AM
MitchStellin's Avatar
I have 502s and they are above the fuel pump at the front left if you are facing them. I have the stainless stick and have found the flexible to be hard to read, people paint the end white so you can see the hole, it is black otherwise. I have pics at home I can post tonight.
MitchStellin is offline
Old 05-12-2004, 02:59 PM
Thanks pic's would be a big help. Here is what I am dealing with. If you can tell anything about it.
Old 05-12-2004, 03:07 PM
JUSTONCE's Avatar
I'd try to avoid any really tight bends as it becomes a ***** to get the dipstick back in.
JUSTONCE is offline
Old 05-12-2004, 10:05 PM
Robert
Thanks Robert I am looking into that now. Are you going to bring that Apache to Jacksonville this year?
Old 05-12-2004, 10:43 PM
See it to the left above the exhaust cooling hose, it is yellow. Hope that helps.
Old 05-12-2004, 10:46 PM
My stick goes in easy, I can't just jam it in and always guide it in so I don't kink it.
eliminatethis
0
09-04-2008 03:47 PM
Rebel_Heart
5
10-03-2006 11:01 AM
razor1115
3
07-28-2003 10:34 PM
dyno
2
06-10-2003 09:24 AM
Raypanic
16
06-29-2002 06:49 PM
Quick Reply: Dip Sticks, Where are yours?
