Like Tree0Likes
Dual axle trailer question
Old 05-21-2004, 10:05 AM
Air Dog's Avatar
My Boats: 1988 banana - Sold, 1993 banana - Sold, 1979 banana - Building, 1978 banana - Building, 1972 Cigarette 20 - Sold, 1997 Scarab Sprint - Sold, 1985 Jaguar Stepped Cat, Gaff-Rigged Schooner
Default Dual axle trailer question
I have a math question for someone.
A normally balanced boat and trailer has about 10% of total weight on the tongue.
My 24 foot boat has -1% of total weight.
My 24 foot boat will sometimes flail around when going to fast due to this.
My 24 foot boat is dangerous to society when on highways.
I need help.
I need to move my axles back, but how far?
The trailer is welded steel with welded steel axles, so I only have one shot at moving it back.
Anybody a math wiz that can help me?
Boat weights 3900 lbs I think. Single engine 200hp Mercury on the transom.
Air Dog is offline
Old 05-21-2004, 10:12 AM
Charter Member #232
Audiofn's Avatar
My Boats: 1979 Formula 302, 99 Formula 353, 81 Donzi 18 2+3 with 454
Default Re: Dual axle trailer question
Do you have a single or dual axle now? How far forward from the back of the boat is the axle or the center of the two? Are your tires properly inflated? What are you towing it with?
My Donzi I can pick up the tounge with my fingure. It trailers perfectly. My hydrostream was the same way. You may have a allignment issue with the axles also. Make sure they are perfectly parallell to one another and straite on the trailer.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-21-2004, 10:14 AM
Charter Member #232
Audiofn's Avatar
Oh ya if you are running a dual axle set up and if one axle is rated to carry the load you could just pull the two front tires and see if that trailers any better.
Jon
Audiofn is offline
Old 05-21-2004, 10:15 AM
cig1988's Avatar
My Boats: 1988 Bullet FOR SALE
Trial and error. If at all possible find a truck scale close by. As long as it's level you can be able to unhook the trailer and take it from there. I'm sure they'll charge you a few bucks to do this but well worth it. I would start at 6" a time. Also if you have any room to adjust the winch stand, that may be easier.
cig1988 is offline
Old 05-21-2004, 12:03 PM
Tantrum's Avatar
My Boats: Stray Cat Statement Marine
Quote:
Originally Posted by Audiofn
My Donzi I can pick up the tounge with my fingure. It trailers perfectly. My hydrostream was the same way. You may have a allignment issue with the axles also. Make sure they are perfectly parallell to one another and straite on the trailer.Jon
You got lucky here Jon. I properly set up trailer should not be balanced, it should be carring about 10% of the gross weight on the tongue, this will change of coarse for very heavy loads but for a 24' Baja that is what I would do.
As suggested above go to a recylcling or scrap yard and get the boat/trailer gross weight. Then you need a portable scale to put under the tongue while you move the axcels back and forth. Also keep in mind that fuel and gear will usually sit in front of the axcels adding to your tongue weight.
Tantrum is offline
Old 05-21-2004, 12:10 PM
ofshore's Avatar
Quote:
I was thinking the same thing move the winch stand forward if possible if not you would need to know the cg of the boat and trailer in order to know exactly where to put the axles. Now that i think about it if the trailer is pretty much balanced now just move them back a 6-8" and you should be ok, i worked with a guy building tandem axle utility trailers and we always set the axles back 12" from center. One more thing, make sure you measure the location of the axles from a good reference point on both sides, if you don't weld them on perfectly square not only will it sway back and forth but you'll be going through tires constantly.
ofshore is offline
Old 05-21-2004, 12:34 PM
MitchStellin's Avatar
My Boats: Zodiac RIB
I just went thru this nightmare. I cut the back off the trailer and moved the boat 2 ft forward. It now sits just right. Jon, you are playing with negative tongue weight. This will cause a fishtail event you will not be able to pull out of. The truck scale is the only way, just drop the tongue on the scale and see where you are. Moving axles is a tough thing to do, you may run into a cross member and not have any wheel travel. Try pulling it forward first.
MitchStellin is offline
Old 05-21-2004, 01:08 PM
Charter Member #232
Audiofn's Avatar
Mitch I am not worried with the Hydrostream if it weighed in at 1000 pounds that was a LOT. The Donzi is also very light for what I tow it with (F350 Dually Diesel) So it aint gona push that truck around. However The Formula is set up properly and it tows FANTASTIC. In fact the new axles, springs, disk breaks, rims, you name it just showed up today so if it rains this weekend I know what I am going to be doing
Jon
Audiofn is offline
Old 05-21-2004, 01:13 PM
The only real way to know is to do it.....
SIMPLEST WAY :
1) Have all the tools handy . ( torch or saw , a welder , jacks , and a scale for the front .)
2)weigh it ,
3)mark it,
4) lift it ,
5)cut the axels off,
6)move them back 6-10" ,
7)just set the weight back on them ,(don't weld it yet )
8)weigh it again ,
9)and move the axels again and weigh it if needed , if not ,weld it there and go boating !!
Easiest way ! I do it all the time . Just did one last night . Good luck ,Joe
boot is offline
Old 05-21-2004, 01:57 PM
Air Dog's Avatar
Talking Re: Dual axle trailer question
You guy's are great.
I threw this thread up there because I was tired of trying to figure it out on my own.
I jumped in my airplane did two flights still thinking about it.
I come back and now I have my solution.
Cannot thank all of you enough.
To answer some of the questions:
It is an, Eagle (I think), dual axle trailer
I can't move the winch stand forward becuase there is no room.
I towed my boat with a dually diesel once and it was fine, but my normal tow vehicle is a Jeep Grand Cherokee and when I get over 65 mph it starts to fish tail.
I am not sure where to find a truck scale, but that is my next step.
Chris
Air Dog is offline
Just another Toy
15
03-11-2008 07:15 PM
sleek1
19
12-02-2007 08:59 AM
Blewbyyou
5
01-23-2007 06:40 PM
dukenrock
4
04-16-2004 12:22 PM
Fountain38
05-23-2003 11:41 AM
