Oil Temps
What oil temp are you running with like motor??
540 c.i. with oil cooler, 871 blower (no intercooler). Thanks |
Re: Oil Temps
I say the hotter the better, 375- 400 sounds right, you really want it to boil and get thin so it flows through the engine nicely
Re: Oil Temps
seriously 230 should be good
Re: Oil Temps
Re: Oil Temps
between 40 and 105 degrees depending on the ambient temperature. mercury 300 EFI
Re: Oil Temps
Re: Oil Temps
On my last blower motor with a inner-cooler it ran about 230 running pretty hard . cruising it would be 160-180.wfo for a while would go to 260 then I would let out. But it was at 11 lbs of boost.I put 140 hours on that one and the bearing looked real good.At that boost the oil would fuel dilute pretty fast, Also the carbs was on the rich side [Safe mode] :D
My Hustler has a oil thermostat in it and it want go over 210.Thats what its set at. :( It would probably run cooler but i change my oil every 25 hours or after every poker run. |
Re: Oil Temps
running casual I see 190*
Max I have seen beating is 220* but water is still cold around here. |
Re: Oil Temps
Originally Posted by Reed Jensen
Yeah.... centigrade......... The oil should be up around the boiling point of water... 200 to 230... anything above 300 and the oil breaks down quickly.. My old air cooled Ducati used to run over 350f all the time... great for deep frying chicken, not good for viscosity life though..... :blaster:
as for I/O type motors oil temp, at a minimum, should be over 212 (boiling point of water). 220-230 would be ideal. I'd probably start to watch it carefully if it went north of 250. |
Re: Oil Temps
Cool thanks. So running at 240 with cold water temps would not damage anything??
| All times are GMT -5. The time now is 01:59 PM. |
