Drying the boat
Old 06-08-2004 | 04:00 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: Drying the boat
It looks great Adam. I love the trailer I got with Monsoon as well. Triple 6K axles; so I could store two jetskis on top of Monsoon just for fun. However I wish I had an explaination as to why one of the spindles is already bent. Its on the middle axle too, which is really strange. I have a replacement on the way which was only $50, but switching it out is going to be a b1tch. I hope it is only a bent spindle causing my tire balding. I went through this on the last boat trailer.
Sydwayz is offline
Old 06-08-2004 | 04:06 PM
97BossHammer's Avatar
chamois as well....of course my boat is not as big as you guys someday though..............someday
97BossHammer is offline
Brian- Moonsoon looks great. Todd took good care of her. As for your trailer, just be glad it's not a ROCKET TRAILER !!!
The middle axle being bent has got me stumped.
Maybe a question for "Hi Tech" on here.
Thunder32 is offline
Old 06-09-2004 | 01:14 AM
Strip Poker 388's Avatar
Rob
I use the blade to get the big stuff off and them use the Absorber drying skin
to finish up. i also use the towells after the blade sometimes.
One thing I have noticed if ya use the towells . Do not use fabric softner or the dryer sheets,They want let it soak up as much water. if there is to much softner in them it will smear on the boat.
The water softners they have out now that hook up to the hose helps on the water spots with hard water.Water spots suck..
Rob
Strip Poker 388 is offline
Old 06-09-2004 | 01:42 AM
Hot Duck's Avatar
We use water blades on the flat areas and then take care of the rest with an Absorber or two.
Hot Duck is offline
Old 06-09-2004 | 03:44 AM
Here is the best materiall to dry the boat in the hole world!!!.
It is smooth, takes a lot of water, oil and other stuff.
if you have an oil spill in the engine room just take a couple of these and throw them under the engine it will suck up al of it in a swish.
http://us.pampers.com/en_US/products.do?navstage=105
cobra860 is offline
Old 06-09-2004 | 04:20 AM
carter38's Avatar
I use the water blade to get the big areas touch up with a towel. The blade cuts the time in half.
carter38 is offline
Old 06-09-2004 | 04:39 AM
Downtown42's Avatar
where do you get water blade?
Downtown42 is offline
Old 06-09-2004 | 07:52 AM
JUSTONCE's Avatar
I should correct myself , I don't use a real chamois, I use an absorber. We got tons of them here at work and they are awsome.
JUSTONCE is offline
Old 06-09-2004 | 08:12 AM
Iggy's Avatar
My daughter gave me one of those Mr. Clean AutoDry wash kits.
It works exactly as advertised. I use it on the boat too. The final rise dries very fast with no towels and no spots.
Iggy is offline
