Octane question
Old 06-14-2004 | 12:45 PM
CJC's Avatar
CJC
Question Octane question
Will too high of an octane hurt an engine?? - I'm only talking gas station stuff, not race fuel or anything. I was told that higher octane fuel actually burns cooler than low octane, thus, better for engines.
I always put at least mid grade stuff in my boat if not "Super". Everbody says I'm waisting my money.
The engine in question is an older Merc. 40hp outboard. What grade fuel would you use??
Sharkey??
Thanks,
Casey
CJC is offline
Old 06-14-2004 | 12:50 PM
Ron P's Avatar
Enjoy the show
Default Re: Octane question
How old? If it's before 78 it should have an unleaded kit.
You'll be OK with 89 octain.
Funny, the new merc 525 can only be run on 87.
Ron P is offline
Old 06-15-2004 | 09:34 AM
CJC's Avatar
CJC
It is a '74 Merc.
Unleaded kit??? Is that a lead additive or a hardware add on?
CJC is offline
Old 06-15-2004 | 11:00 AM
JUSTONCE's Avatar
higher octane is more stable, so it won't predetonate under higher compression. If you have a low comp. engine the higher octane is not giving you any benefits.
JUSTONCE is offline
Old 06-15-2004 | 11:14 AM
GregP's Avatar
Higher octane gas burns slower and will cost you HP if the motor doesn't need it for detonation protection. Dyno shows a 2-3% loss running 103 -vs- 85, but we have to match the host fuel requirements. They do run cooler on higher octane.
-Greg
GregP is offline
Old 06-15-2004 | 12:56 PM
CJC's Avatar
CJC
Good information.
Thanks guys!
Casey
CJC is offline
Old 06-15-2004 | 06:27 PM
BAJA WILL's Avatar
Registered User
Take it for what you want we have 1998? 90hp outboard on the Poontoon, it runs like chit on 87, cuts out and stuff, we run 89 or higher in it and runs great. As for 500efi runs the same on 87 as 93, I can't tell a change?
WILL
BAJA WILL is offline
Old 06-15-2004 | 06:32 PM
Hydrocruiser's Avatar
Arrow Re: Octane question
Origin of the 'Higher Octane is Better' Concept
Higher octane gasoline did reduce engine knock in older engines that used carburetors to regulate the air/gas mix. The older engines could not regulate the air/fuel mix going into the engine as efficiently as a computerized fuel injector. A carburetor in need of adjustment could cause too much fuel to be mixed with the air, which meant the gasoline would not burn completely. The excess gas soaked into carbon deposits and caused a premature ignition of the gasoline from the heat of the engine cylinder. The premature ignition made a sound that came to be known as 'engine knock.' When this happened, people would change to the higher octane/slower burning gasoline to resist the premature burn, thus minimizing the knock. Upping the octane was beneficial then, but engines and gasoline formulations changed.
Since the mid-1980s engines use fuel injectors with computers to accurately control the air/fuel mix over all temperature and environment ranges. The accuracy of the fuel injectors and computers is based on using the recommended gasoline for that engine. Most cars are designed to burn regular unleaded gas with an octane rating of 87. If the vehicle needs a higher octane rating this requirement is noted in the owner’s manual and usually under the fuel gauge and by the gas tank.
Some gas companies are better at quality control. The first thing to do if you suspect a knock at a specified octane is switch to a different brand.
Hydrocruiser is offline
seef158
19
03-08-2008 10:14 AM
jonholmb9
10
05-13-2004 08:08 AM
36spectre
08-04-2003 09:52 PM
zog02
22
02-04-2003 07:46 AM
THRILLSEEKER
6
06-07-2002 03:17 PM
