POLL: which oil do you use ? >
View Poll Results: What oil do you use in your stock power big block ??
25-40
51
9.01%
15-40
28
4.95%
20-50
87
15.37%
straight 40
90
15.90%
straight 30
19
3.36%
syntec
9
1.59%
mobil 1
183
32.33%
amsoil synthetic
45
7.95%
R.P.
21
3.71%
OTHER
33
5.83%
Voters: 566. You may not vote on this poll
Old 05-13-2005 | 08:33 PM
  #81
Papache's Avatar
Registered User
Default Re: POLL: which oil do you use ?
5w 30 the trick is to keep the temperature down
Papache is offline
Old 05-14-2005 | 02:37 PM
  #82
Hydrocruiser's Avatar
Arrow Re: POLL: which oil do you use ?
Just curious what engine you are running...oil temps and pressure....are you set-up to run that low of a viscosity..journals..oil pump...coolers? If you are running 11 qt oil pans and a high volume pump you may be ok with a Super premium Synthetic 5W-30 in a big marine engine.
Just curious. the lowest viscosity I have seen used is a
10W-40 Super Premium.
Illmor tested the Dodge Viper marine engines and found the 10W-30 for street was not sufficient to develop a proper film at constant nearredline use.. so they moved up to 15W-50 Mobil-1.
Hydrocruiser is offline
Old 05-18-2005 | 02:22 PM
  #83
fund razor's Avatar
I run straight 30 weight dinosaur oil.
At up to 260 peak horsepower, my engines deserve no less.
That and the manufacturer recommended it before they went under.
fund razor is offline
Old 05-18-2005 | 07:17 PM
  #84
Some very intensive tests show now that 5W-30 or 10W-30 synthetic oil such as Mobil-1 are equal or better than 30wt dino juice. If you have 260HP you probably have a 350 Chevy that could easilly take a 15W-40 or 15W-50 either of which is superior to 30wt.
Teague says if you use straight weight oils to use:
30wt for cool climates
40wt for moderate climates
50wt for hot climates.
If you go straight conventional he is correct in these suggestions.
Old 05-19-2005 | 08:20 AM
  #85
fund razor's Avatar
Should I use multi-vis Hydro?
You are the freaking Pope of oil.
Old 07-21-2005 | 08:26 PM
  #86
Truly..I think only multi-vis if synthetic.
Otherwise..
30wt 70*F
40Wt 80*f
50WT 90*F
Old 07-21-2005 | 08:28 PM
  #87
I figured I was the "Pope of oil" when the white smoke started pouring out the back end of my boat...
Old 09-09-2005 | 08:47 PM
  #88
Mentalpause's Avatar
Did you buy a boat? What did you get?
Mentalpause is offline
Old 09-09-2005 | 09:25 PM
  #89
I use Straight 50w and change approx 20 hours no problems yet!
abones is offline
Old 09-09-2005 | 09:31 PM
  #90
I am on the waiting list for a new Skater... I figured all or nothing...
