Who makes the best blower/supercharger? >
View Poll Results: Who makes the best blower/supercharger?
The Blower Shop
17.47%
BDS
9.68%
Mooneyham
2.69%
Dyers
0.54%
Weiand
1.88%
Holley
1.08%
Littlefield
5.91%
Whipplecharger
43.55%
Procharger
11.83%
Vortech
5.38%
Voters: 372. You may not vote on this poll
Old 10-05-2004 | 07:52 AM
  #61
mcollinstn's Avatar
Default Re: Who makes the best blower/supercharger?
This is the "logic" I use in assigning "ownership" of a part...
Regardless of what facility casts/forges/or fabs a particular piece, if the part is built to a customer design and to an exclusive SPEC than that part "belongs" to the entity who "ordered it". At least in the case of outdrive castings, if they are MERC spec and are not made available to any other, then they are MERC castings. Just done outside. Still Merc castings.
On the other hand, stuff like Dart intakes with bronze liners and a Merc emblem are NOT merc parts. Gil manifolds with Merc cast into the sides are NOT merc parts. A Weiand blower housing with a Merc emblem on the side of it is NOT a merc part. Even those H-beam rods with Merc on the beams aren't Merc parts (they are somebody else's rods with a "private label" sort of character mark on them).
mcollinstn is offline
Old 07-27-2005 | 11:47 AM
  #62
fund razor's Avatar
Dam...
I got fooled.
I thought MC was back.
fund razor is offline
Old 07-27-2005 | 01:35 PM
  #63
JohnS's Avatar
My preference is for roots type as they are "displacement" compressors. You get a fixed volume of air/fuel for every revolution, regardless if its 500 or 5000 RPM. Very predictable and the efficiency increases only slightly as you get up in RPM's (80% adiabatic max). You feel the torque throughout the entire range.
I haven't owned centrifugal units, but they are basically belt driven turbo's.
I was under the impression that cent. blowers were more efficient at higher RPM's but suffered from boost lag, and the boost pressure went up exponentially as RPM's increased. Not a good thing if you are constantly leaving the water and going from 5 to 10#. I know waste gates control the psi, but still a scary proposition for my taste.
Besides, twin blowers through dominators at 5500 RPM sounds like a 747 is chasin’ ya.
JohnS is offline
Old 07-27-2005 | 08:40 PM
  #64
Coolerman's Avatar
PF Marine
So while we are talking about blower efficiency, i heard from a very good source that on a top alcohol funny car, a 1471 takes about 1000hp to spin and a PSI only takes 300hp or so. Just a random fact to throw out.
Coolerman is offline
Old 07-27-2005 | 09:13 PM
  #65
ratman's Avatar
screw superchargers like the psi work so well the nhra limited the amout pat austin could overdrive his screw supercharger and the roots guys could over drive thiers as much as they wanted. they did it to level the playing feild cuz austin was kickin everybody azz in alcohol funny car
ratman is offline
Old 07-28-2005 | 07:08 PM
  #66
Nobody..........
AND don't say Whipple because they can't and will not have anything for LONG LONG time....so its LIKE they are out of business
enticer is offline
Old 08-08-2005 | 10:53 PM
  #67
vette131's Avatar
Originally Posted by MYPANTERA28
This can get out of hand to what is best, for myself BDS has terrible
customer service but their blowers are the best. I have seen in many
of the top engine builders shop remove the whipple and install a roots
blower instead. To each its own, you run what you want, this is
strictly my own opinion on this topic.
the only reason an engine builder would remove a whipple to use a roots, is to save a drive from too much power. care to name the many top engine builders??? i love the way roots look & how simple they are, but if you want to make big power it's whipple or procharger.
vette131 is offline
Old 08-09-2005 | 10:56 PM
  #68
vette131's Avatar
ttt
vette131 is offline
Old 08-12-2005 | 04:05 AM
  #69
I hate to chime in an old thread, but seriously folks... it's either turbo or whipple...adiabatic wise, they are very similar, other than the lag factor. The controlling factor is cylinder pressure and octane. Keep in mind that octane requirements increase based on time and heat.
RichardCranium572 is offline
Old 08-14-2005 | 07:09 AM
  #70
vette131's Avatar
how do psi's stack up???
vette131 is offline
