Tightning down props
Old 07-17-2004 | 05:22 PM
Jassman's Avatar
Default Tightning down props
Whats the best way to tighten down a prop, other than using a piece of wood. I know I've seen some type of tool. The Nortech is on the lift now, and its hard to tighten the props down since I can't brace a piece of wood off the trailer. Thanks Jeff Jassby
Jassman is offline
Old 07-17-2004 | 05:58 PM
Strip Poker 388's Avatar
Rob
Default Re: Tightning down props
I use a peice of wood between the cavitation plate.
Jeff where's your trailer
Eric (Racerx6) said he caught up with yall out at Cat Island the other weekend . You missed a good time out there for the 4th .
Rob
Strip Poker 388 is offline
Old 07-17-2004 | 06:02 PM
Blade38's Avatar
Wood between the cav plates
Blade38 is offline
Old 07-17-2004 | 07:58 PM
robyw1's Avatar
today i jest use my hand aginst the cav-plaet. OUCH i can't not type
Roby
robyw1 is offline
Old 07-17-2004 | 08:07 PM
HotPursuit's Avatar
Total Marine and Performance, For your hi performance needs, custom power, performance upgrades and accessories. 1-(985) 649-9888 or call my cell 1(228) 216-0900 Thanks, Jeff Jassby
The condoms yall hand out won't work? Maybe a piece of 4X4 will.
GETT WOOOD!!!!!!!
HotPursuit is offline
Old 07-17-2004 | 08:24 PM
traviss's Avatar
good ole wood I use it on my BIGGGG 3 blade and my HUUUGE alpha drive and a huge impact gun
traviss is offline
Old 07-17-2004 | 08:30 PM
Steve 1's Avatar
Jeff have a carpenter make a wooden Jig that slides in and over sandwiching the cavitation plate with a thick softwood block on the bottom side to lock/bind the Prop.. I Made a couple for the race Boats the Rollas were very sharp. That way it is a one Man job.
As always Best Regards
Steve 1 is offline
Old 07-17-2004 | 08:53 PM
Combination prop tightening kit........PT # 104-033PK01
enticer is offline
Old 07-18-2004 | 12:01 AM
xxxtreme171's Avatar
GETT WOOOD!!!!!!!
Problem with the condoms is they are xtra small...lol
xxxtreme171 is offline
Old 07-18-2004 | 05:38 AM
I got wood! (kind of). I use a chunk of 4x4 and a torque wrench set @ 100 ft lb on my Speedmasters. It's all I can afford after making the boat payment and paying for the insurance, slip fee, heated winter storage and outragous gas prices! Lou
Lmarth is offline
