525sc Pulleys???
Old 08-13-2004 | 05:04 PM
iamfaster's Avatar
Default Re: 525sc Pulleys???
To The Wood, I called Teague a couple weeks ago and they claim they use the pulleys to fit your motor. They use them for their Blower/ intercooler set up on the B&M 174's. I assume they r star splined. 2 3/4". They use the smaller pulleys to make up the boost lost after runner the intercooler set up. Also, Nickerson performancr in PA told me he has a pair for your blower ( I have same motors- 96' 525sc's) @ 2 3/4". I got a pair of original 3" through CP Performance and I still had to file the inside of the Pulleys to get them to fit. You may have to do this as well. Also, Wilson Arms Co. in Fl. 912-265-0774 may be able to fafricate a set for you. He makes pulleys for Chief engines. i am sure he will need some originals to "knock-off. By the way, I have a pair of 2 3/4" shallow dish splined that i took of my motors for the originals. I was afraid to run 8+ lbs without coolers, but i may need them in the future.
Good luck, what kind of boat you running
iamfaster is offline
Old 08-15-2004 | 08:02 AM
carney's Avatar
I have a set of smaller pullies that fit a 1997 525 sc. I do not know how much boost they made but I think they were around nine. I also think that you must put more tension on the belt . when they were on my motors at high rpm the belt would slip from time to time, I went back to stock pullies.
carney is offline
Old 08-15-2004 | 08:31 AM
Payton's Avatar
Charter Member #927
What carb did Merc put on their 525SC? Is it one 850?
Payton is offline
Old 08-15-2004 | 08:38 AM
1HYPER1's Avatar
My Mercury 525 sc,,s came with 1050 dominators,painteb blue just like the engines.
1HYPER1 is offline
eliminatethis
Classic Offshore
0
02-26-2008 04:05 PM
boat4life
2
04-07-2004 06:57 AM
robert johnson
0
04-20-2003 11:27 AM
HyperBaja
02-09-2003 06:28 PM
88 MACH 1
8
08-19-2002 08:20 PM
