Reverse rotation engine question ... >
Old 08-16-2004 | 12:11 PM
Default Re: Reverse rotation engine question ...
Bigyellow, just wondering, what size motors are they ?
boot is offline
Old 08-16-2004 | 12:19 PM
outer42's Avatar
boot bring that boat to me,i'll get it going for you!!!!!!!!!!
outer42 is offline
Old 08-16-2004 | 12:32 PM
formula31's Avatar
Originally Posted by boot
Hey Bigyellowcat, You didn't change anything in the bottom end ? What about the seals ?
How much time do you have on them now ? Thanks for your reply !
Ive got an open, reverse, short block in my shed. Ill look at the pistons and crank tonight to see if the pistons are reversed or if the crank oil holes are different.
formula31 is offline
Old 08-17-2004 | 09:53 PM
NICE !! Thanks for the info !
boot is offline
Old 08-18-2004 | 09:18 AM
Michigan Mad Man
one thing you need to do is polish the crankshaft in the direction of rotation because when polishing the crank it raises the metal and you do not want your oil flow going against the raised metal. Tyler
TylerCrockett is offline
Old 08-18-2004 | 09:42 AM
Merc and most marine builders reverse their crankshaft rotation but maintain normal cam rotation by using a gear rather than chain drive. That way you can use a standard distributor/oil pump setup. Cam is a different grind. The crankshaft p/n for merc is the same on left vs right rotation, so that doesnt seem to be an issue. Pistons and rods are also the same p/n. I've heard about reversing the pistons on older engines, not sure about that though. Only the rear seal is different, yellow instead of blue. Although there are people on this board using the wrong seal without problems. Front seal is the same.
That being said, Bigyellowcat pointed out you can reverse the rotation of both the crank and cam with a few modifications.
I hope formula31 can shed some light on piston direction.
Gary
Gary Anderson is offline
Old 08-18-2004 | 09:49 AM
Gary
You can use a non-directional seal on both.Some seals have groves(yellow/blue,rear main) to keep the oil in the pan .
Dixie Doug is offline
Old 08-18-2004 | 09:58 AM
Official OSO boat whore
If you reversed the oil pump, what would that do to it's flow?
Cord is offline
Old 08-18-2004 | 10:05 AM
BigSilverCat's Avatar
you cannot reverse the oil pump it needs to still turn the same direction.
BigSilverCat is offline
Old 08-18-2004 | 10:52 AM
I was wondering if that was why his buddy took out his crank bearings...
Cord is offline
