towing tips.
ahhh... speedo.
That explains it.
Don't want to be negative... seems like I slammed these boats pretty hard...
You will probably see about 55 on a gps if it's trimmed out right and everything else is ok. (Clean hull, not a full tank).
That explains it.
I Have A Question We Just Bought A Topgun With A Manning Poker Run Edition Trailer. I'm Looking To Buying A 01 Dodge 2500 Diesel Extended Cab Short Bed .my Question To Yall Is Do Yall Think It Would Make A Difference Short Bed Compared To Long Bed? Thanks For Your Advise In Advance
Donz Jr Mike
Donz Jr Mike
In a panic steer the longer wheelbase is gonna be way stabler, and if your using fifth wheel you need the slider hitch with the shortbed, so when manuvering you slide the wheel back to keep the trailer from hitting the cab.
