Whats the best chip/programer for 04 Cummings >
Old 08-18-2004 | 06:14 PM
Default Re: Whats the best chip/programer for 04 Cummings
TST is a good unit along with Edge. These are my two favorites. I am running an EZ in my 03' along with a set of 100hp injectors. Along with NUMEROUS tranny and airflow upgrades. I have ordered a TST for the second time, (early units were throwing lots of codes and signaling delayed pilot injection...all fixed now) I can't wait to see what the TST stacked with the edge will do
As stated before, the TST will destroy a factory automatic tranny and will burn a clutch up very quickly if you aren't careful.
Lonestar
lonestar382 is offline
Old 08-18-2004 | 08:15 PM
Lonestar
Only if you put it in mdes that you are not supposed to. I know it is hard to discipline yourself sometimes.
OffshoreOnly is offline
Old 08-18-2004 | 08:32 PM
LapseofReason's Avatar
Dam that thing looks cool with the 22.5's on it. Keep all the info coming, he wont be able to read all of it till tomorrow when I get to work and log on but this is the most expensive thing he has ever had so I know he wants the best for it.
On the other hand I need to get a big truck to pull the Nor-Tech she is 25k lbs. with the trailer and the F350 hates it. I want to find an older truck in the 19k-26k lb. range either crew cab or sleeper for under $30k I only pull it about 5-10k miles a year so I don't want to spend a ton of cash. And I have a 00 F350 cc dually 4x4 loaded for sale, it has some stuff done to it 64k miles.
LapseofReason is offline
Old 08-18-2004 | 08:40 PM
dhlaw's Avatar
Steve,
what did the 22.5's set you back? Did you get spacers as well?? Are there spring cups in the front?? I am gonna get me some!!!
dhlaw is offline
Old 08-18-2004 | 09:03 PM
robyw1's Avatar
I say Dodge is the best chip programer.... leave it alone
Roby
robyw1 is offline
Old 08-19-2004 | 12:34 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Damn, Shuble's truck looks tight like a mo-fo.
Sydwayz is offline
Old 08-19-2004 | 07:28 AM
From: A tree somewhere in the woods in Clarcona Fl.
Personally used the Edge products programmer on my 6.0 powerstroke and love it, digital readout/moniter and can change programs on the fly. Had a superchips programmer on my old 7.3 powerstroke,(wasn't user friendly) had to reprogram everytime I hooked up the boat.
Slick02 is offline
Old 08-19-2004 | 07:52 AM
Law,
The 22.5 Alcoa's and tire package with adpaters run about 4K. I found a used set with low miles from a guy that sold a truck and removed them. Another $300 or so to balance them on the proper machine. Attached is a picture of a 2" spacer that replaces stock spacer in the front to accomodate the larger wheels and tires. The adapters are manufactured by Reds in Miami but most truck places sell the entire kit installed and get the adapters for you. My set had Dunlop tires by I would get the Michelins if I was buying new.
Attached Thumbnails Whats the best chip/programer for 04 Cummings-dsc09940.jpg
Old 08-19-2004 | 09:21 AM
Steve,
Your truck is awesome. You are the man!!! Now i just need to get some of those for my f-350. And how does that thing ride with those tires?
BobbyB is offline
Old 08-19-2004 | 10:29 AM
Thanks. Rides fine, Obviously not as good as stock but once the boat gets loaded it rides beautiful. All the Fords and Dodges in FL run the semi tires. Might not be so great in the snow for those up north though.
chuckd1025
23
01-07-2008 02:15 PM
BY U BOY
09-20-2007 09:47 PM
bcfountain
5
05-16-2007 12:59 AM
BajaRunner
5
10-12-2006 02:28 PM
dean51267
10
03-05-2006 05:23 PM
