Mr. P has been screwed
Old 08-28-2004 | 12:42 PM
rjcardinal's Avatar
Default Re: Mr. P has been screwed
Pics of 9 in the heel and a plate. Mine are permanant. In there forever. Im not a big guy 5'8" 175lbs. All stainless steel and will set off the airport detectors. The heel (calcaneous) is an odd shaped bone. Once you shatter it , mine was in 5 pieces, you need something to hold it in the correct shape while it heals. The bone will heal fine without the screws but the shape of the bone need to be the same as original to walk normally again. I asked the doc why he couldnt drive the screws any straighter and he said the strap or plate that the screws go through is the correct shape for the bone and the screws need to be in all those angles to hold it together. Once you look at the top view you can see that all the screws are evenly spaced and in there the only way you could get all of them in there.
Modern medicine is simply amazing!
rjcardinal is offline
Old 08-28-2004 | 01:17 PM
cuda's Avatar
Did he have to drill pilot holes??
cuda is offline
Old 08-28-2004 | 01:38 PM
rjcardinal's Avatar
Cant remember! I was asleep!
Ron
Old 08-28-2004 | 01:59 PM
PatriYacht's Avatar
Originally Posted by Too Old
I agree....You sure you didn't install those? They look pretty long and are in a sort of random pattern.
The metal detector at the airports are going to be fun.
They do look like quite a bit of screw sticking out of the bone. I may not be wearing normal shoes for the next 4 months. I'm afraid to look under the bandage now.
PatriYacht is offline
Old 08-28-2004 | 05:47 PM
Charter Member #319
That hurts just looking at the pictures
“He who is unaware of his ignorance will be only misled by his knowledge.”
ΜΟΛΩΝ ΛΑΒΈ!
bajabob38 is offline
Old 08-28-2004 | 05:55 PM
Wasabe's Avatar
Daaaaaaaamn!
Wasabe is offline
Old 08-28-2004 | 06:04 PM
Damn Ron, you weren't kidding about the erector set look. Hang in there and you'll be almost good as new before you know it. Once again, if you or D needs help with anything, don't hesitate to call. I've got a lot of spare time now.
jmeng is offline
Old 08-30-2004 | 07:46 AM
rchevelle71's Avatar
Originally Posted by Ms PatriYacht
3 times actually, I think the doctor stopped at Home Depot on the way
to surgery yesterday
Wouldnt be the first time!!!
http://www.z-kat.com/
I build the image guded equipment and software used in installing screws, plates, and implants, Home Depot is one of our approved suppliers!!!!
rchevelle71 is offline
Old 08-30-2004 | 07:47 AM
super termoli's Avatar
damn mike! that's cyborg stuff right there
BTW, what happened?
super termoli is offline
Old 08-30-2004 | 09:11 AM
dyno's Avatar
Charter Member #655
WOW!!! he better be callin he Mrs. for some rehab!!!! Novacare Rehabilitation....state wide! Good luck with the recovery Ian!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
