Fountain Help
Old 09-30-2004 | 01:41 PM
Default Re: Fountain Help
The numbers on the "can", near the base of the ears, may be the sequence number for tracking the lab work, if they keep track of their "lab jobs" - kinda like a serial number for that lab job, not the pitch. The numbers on the end of the hub, behind the prop nut and washer would indicate what pitch the castings were, but, since they were labbed, those numbers are probably meaningless anymore. Several of the Hydro's that I have had reworked have a string of numbers stamped in the "can" such that the company that did the work can "look up" what they did to my props. If 2 were worked on in a row, I would expect that it would be XXX and XX(X+1). It may just be coincidence that he has 31p props and that the sequencing of lab work was 31 and 32. It could have been 63 and 64, probably as the last 2 digits. I am not saying this is what he has, but just a thought, from other work that I have seen.
bob_t is offline
Old 09-30-2004 | 07:50 PM
THATS IT's Avatar
Originally Posted by throttleup
With the information you have provided your props were labbed by Hydromotive Engineering.
Are, your props turning inward or outward?
Julie
THEY TURN IN... ARE THOSE NUMBERS THE PITCH?
JOE
THATS IT is offline
Old 09-30-2004 | 08:00 PM
THATS IT's Avatar
Well It Looks Like I Got Some Tweaking To Do.
I'll Get In Touch Hydromotive And See What They Say.
I'll Also Swap The Props And Try That.
I'll Post The Results!
Joe Pasko
THATS IT is offline
Old 10-01-2004 | 12:16 PM
Here's something to check,
I've seen instances where the trim spacer
( ITEM 30)
installed towards the
rear.
This doesn't allow as much negative trim.
here's the picture showing the spacer:
http://www.mercruiserparts.com/Show_...%28STANDARD%29
I've seen this cause planing difficulties.
JaayTeee is offline
Old 10-01-2004 | 11:17 PM
get a cigarette
donz jr mike
thedonz is offline
Old 10-02-2004 | 07:30 AM
epeek's Avatar
Originally Posted by thedonz
get a cigarette
donz jr mike
If you wanna go slow.
epeek is offline
Old 10-02-2004 | 07:51 AM
InXS's Avatar
Not an expert, But I have heard and read that Extension boxes hinder low speed manueverablity (especially in reverse). I also would try a set of Bravo 1 props (From Julie of course )
I agree also. Especially true when the props are turning in (low speed manueverability more difficult).
InXS is offline
Old 10-02-2004 | 11:52 AM
i think he means if ya want to have fun in the rough waters (play with the big boys) and not have a hull that cracks or a free board that will throw ya over board,or have a boat that in the title it says 42 and it's really a 38. another thing is if ya want to have another production boat that there's like 100 that look the same. yea there fast i won't lie but make sure ya stay below 2 foot chops and mostly in lakes . but now if your not looking for any of these then yeah buy a fountain.
donz jr mike
thedonz is offline
KennyOffShore
Offshoreonly Industry News
0
08-06-2008 10:14 AM
joejohn
Fountain
25
04-06-2008 08:33 AM
DannyD
02-11-2005 10:54 PM
Blade38
08-11-2002 10:26 PM
