Weight of #6 vs ASD-8
Old 10-09-2004 | 06:29 AM
Jassman's Avatar
Default Weight of #6 vs ASD-8
Anyone know the weight difference between the two, including transmissions. Thanks Jeff
Jassman is offline
Old 10-09-2004 | 06:39 AM
mtm's Avatar
mtm
Default Re: Weight of #6 vs ASD-8
JASSMAN did you sell your # 5 ssm
mtm is offline
Old 10-09-2004 | 07:42 AM
Jassman's Avatar
MTM, I haven't really tried, I have had 5 offers, and had to turn them away, cause I had someone buying the boat. But...that 3 month ordeal just fell through, alot of strokes in this world, and dummy me, should have collected a deposit, and not take the persons word. I'm going to the FT Laud. show to check out the latest changes and fads, and then order a new one, if can be traded in. Plan B. is if I don't get a new boat, I will be selling everything off the transom back and setting my Nortech up with new Weisman drives, and then upgrading my power with Whipples, should be a nice winter project. Sandy says "your never happy", always changing your boats and cars, the only thing I've kept is her for 19 years. Thanks Jeff
Jassman is offline
Old 10-09-2004 | 08:16 AM
NJSONIC's Avatar
Jassman,
Heres a page from Arneson they list all the specs for all their drives. http://arneson-industries.com/Arneson%20Ratings.htm
I couldn't find a weight spec for the #6.
Hope this helps.
NJSONIC is offline
Old 10-09-2004 | 08:35 AM
cougarman's Avatar
#6 is 500lbs with transom assembly, not sure what the tranny weighs.
Cougarman
cougarman is offline
Old 10-09-2004 | 01:43 PM
Reed Jensen's Avatar
Cougarman
BW velveeta's are about 100 lbs...
Reed Jensen is offline
Old 10-09-2004 | 01:48 PM
Hey Cougarman... another of Carroll Shelby's favorite sayings was this.... Aerodynamics is just an excuse for not enough horsepower........
Old 10-09-2004 | 02:19 PM
The Menace's Avatar
Tranny weighs approx 85-100 lbs.
#8 approx 300 lbs.
Transom plate 30 lbs
Drop Box 125 lbs
two gears 10 lbs each
chain 35 lbs
tail shaft 35 lbs
torque tube 35 lbs
2 ratio sleeves 2 lbs each
Fluids and bearings
The Menace is offline
Old 10-09-2004 | 03:01 PM
MarkSmith's Avatar
The transmission if about the same. The tailstock is different.
MarkSmith is offline
Old 10-09-2004 | 04:51 PM
bw tranny is 109lbs
open87 is offline
