Automatic Engine Compartment Heater.. >
Old 10-18-2004 | 10:14 AM
Ted G's Avatar
Default Re: Automatic Engine Compartment Heater..
Yup, that's the one!
www.cbpba.com
Ted G is offline
Old 10-18-2004 | 10:47 AM
Do dipstick heaters work?
burtandnancy is offline
Old 10-18-2004 | 06:51 PM
wwwTOPDJcom's Avatar
they are usually less than 100 watts, and as stated above wont protect the oil or power steering cooler, engine compartment needs to be above freezing. dip stick heater most likely wont help against manifolds freezing.
you would really need to monitor the internal engine compartment.
"Brian" Sydwayz had a great Idea with that remote temp.
wwwTOPDJcom is offline
Old 10-19-2004 | 06:43 PM
Keith's Avatar
CBPBA's Walmart Greeter
Brian, you can winterize both engines in less than 2 hours, 90 minutes or less if there's an extra pair of hands to help. So I'll bite, why are you looking at bilge heaters?
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 10-19-2004 | 06:59 PM
MitchStellin's Avatar
I did it with a buddy in 1/2 an hour, we pull the thermostats so it is fast. I pour it into a funnel on the muffs and it sucks like a ho, then he fogs at the last 3 gallons. I used 6 in each. It was $60.
MitchStellin is offline
Old 10-19-2004 | 07:27 PM
Brian,
If you want one let me know. I know some idiot that works at Boaters World
BobbyB is offline
Old 10-20-2004 | 12:45 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Eh, call me anal. I even have 496HOs with fresh water cooling and the air pump system to drain the motors of fresh sea water. I just don't plan on doing to fully monty winterizing because the boat is supposed to be going to FL for the winter.
Sydwayz is offline
Old 09-01-2005 | 09:45 AM
wrh3's Avatar
Boater's World and West Marine both carry a new line of marine bilge heaters that are small and easy to mount, XtremeHeaters. I have a buddy with one and he has been happy with it, YMMV.
wrh3 is offline
Old 09-01-2005 | 10:03 AM
WWW.XTREMEHEATERS.COM
IT EVEN LOOKS COOL ENOUGH FOR A GOOD LOOKING ENGINE COMPARTMENT
they are small and can be mounted permanent out of the way
so you can enjoy those awesome days that always pop up
xtremeheaters is offline
mcraymond3
04-04-2014 11:55 PM
danh63
Baja
7
02-26-2007 09:33 AM
BajaRunner
2
08-31-2005 12:56 PM
BWebb
2
04-29-2004 10:25 PM
