Callan at the 2004 Shootout >
Old 10-25-2004 | 10:38 PM
JCPERF's Avatar
Default Re: Callan at the 2004 Shootout
my brother Timmy who works for Pompi told me your chase boat had a real hard time getting to the boat after your run.He said you were sinking.
JCPERF is offline
Old 10-25-2004 | 10:43 PM
masher44's Avatar
I am not sure if that boat will look good with the brown racing stripes on the seats now.
masher44 is offline
Old 10-26-2004 | 05:50 AM
Canada Jeff's Avatar
Originally Posted by tachyon
The boat has two braking systems. Each drive line has a brake and the boat has two chutes both of which are manually deployed. After the rudder broke, we cut the throttles, the hull settled, and then applied the brakes. We didn't need to deploy the chutes as the boat decelerates amazingly well with the brakes. The ride wasn't as bad from the cockpit. The GPS recalls were 206 and 207...
I forgot about the brake system, are yours electric aplied? Or can you feather the pressure manualy?
Canada Jeff is offline
Old 10-26-2004 | 09:35 AM
How do the brakes work?
jeaston is offline
Old 10-26-2004 | 09:45 AM
tachyon's Avatar
Originally Posted by open wide
Tachyon, did the boat make a hard right turn when the rudder broke? I was at the start line, and when looking down course it looked as if you made a fast right turn towards the end of the course.
It made a gradual right turn after the finish line. We were straight but real loose over the line...
tachyon is offline
Old 10-26-2004 | 09:50 AM
tachyon's Avatar
Electrically actuated hydraulic (titanium) discs with with dual 4 piston calipers. We spin the prop just under 10k rpm at the Shootout...the brakes get a work out when applied.
tachyon is offline
Old 10-26-2004 | 11:13 AM
Lofty's Avatar
Tachyon, I'm looking forward to seeing your new hull. When's it comming out of the mold? I'm planning a trip out your way and want to check out the progress. I understand your're re-powering w/ V12's?
Lofty is offline
Old 10-26-2004 | 12:29 PM
Apply the brakes to shift to right?
Old 10-26-2004 | 01:10 PM
Thank you, guessing that has something to do with the turbine. The boat really looked good running. Again thanks
jeaston is offline
buggyride
09-16-2007 05:19 PM
289FIA
28
11-15-2005 09:16 PM
Qball
General Racing Discussion
14
08-29-2005 02:34 PM
jeaston
10-15-2004 10:30 PM
