496HO, Elisha Cuthbert, and Anna Kournikova
First, Chris and I have a question about the 496HO and winterizing. Please see here:
http://www.offshoreonly.com/forums/s...ad.php?t=89279
In a nutshell, do you have to warm up a 496HO closed cooling motor before running antifreeze through the sea-water portion of the system? Is there any thermostat on the heat exchanger, or other portion of the SEA-WATER side of the closed cooling?
AND
I have become a big fan of Anna Kournikova since joining OSO, especially due to the efforts of Chris288.
However, due to recently seeing the move The Girl Next Door, I do believe Anna has due competion in the shearly amazing catagory. See below for Elisha Cuthbert.
Lets let OSO be the judge.
Anna:
Elisha:
AND
Anna:
Elisha:
Re: 496HO, Elisha Cuthbert, and Anna Kournikova
Brian, Thanks for the PROPS !!! I saw the movie and thought Elisha was pretty hot,, but i'm not a big fan of the " butt " chins,,, Anna still rules for me... !!
P.S. About the H.O.,,, I did get anti-freeze out of the exhaust tips,, but was also wondering if the heat-exchanger has some sort of thermostat...
I always warmed the motor up completely in the past,, just couldn't do it this time,, I'm just trying to figure out if I should go back and re-do it.. ?? Chris
AT Cult Member #3
Cap, Are you bringing your woman with you to KW? Cuase you know if you need an escort service down there you never know what you may end up with
